Printer halts at first Z-probe attempt April 11, 2022 11:53AM |
Send: M119 Recv: Reporting endstop status Recv: x_max: TRIGGERED Recv: y_max: TRIGGERED Recv: z_max: TRIGGERED Recv: z_probe: TRIGGERED Recv: okWhen it is released the state changes to Open. Here is the output with activated probe at position X100 Y100 Z80
Send: M119 Recv: Reporting endstop status Recv: x_max: open Recv: y_max: open Recv: z_max: open Recv: z_probe: open Recv: ok
Send: G29 Recv: echo:G29 Recv: >>> G29 X100.00 Y100.00 Z88.00 Recv: Machine Type: CoreCartesian Recv: Probe: FIX_MOUNTED_PROBE Recv: Probe Offset X-34.40 Y10.60 Z4.50 (Left-Back & Above Nozzle) Recv: Auto Bed Leveling: BILINEAR (disabled) Recv: Recv: current_position= X100.00 Y100.00 Z88.00 : Probe::set_deployed Recv: deploy: 1 Recv: Probe::do_z_raise(10.00) Recv: >>> do_blocking_move_to X100.00 Y100.00 Z88.00 Recv: > X100.00 Y100.00 Z88.00 Recv: <<< do_blocking_move_to X100.00 Y100.00 Z88.00 Recv: >>> do_blocking_move_to X100.00 Y100.00 Z88.00 Recv: > X100.00 Y100.00 Z88.00 Recv: <<< do_blocking_move_to X100.00 Y100.00 Z88.00 Recv: reset_bed_level Recv: >>> Probe::probe_at_point X100.00 Y100.00 Z88.00 Recv: ...(20.00, 20.00, raise, 0, probe_relative) Recv: current_position= X100.00 Y100.00 Z88.00 : Recv: >>> do_blocking_move_to X100.00 Y100.00 Z88.00 Recv: > X54.40 Y9.40 Z88.00 [...] Recv: <<< do_blocking_move_to X54.40 Y9.40 Z88.00 Recv: current_position= X54.40 Y9.40 Z88.00 : Probe::set_deployed Recv: deploy: 1 Recv: >>> Probe::run_z_probe X54.40 Y9.40 Z88.00 Recv: >>> Probe::probe_down_to_z X54.40 Y9.40 Z88.00 Recv: >>> do_blocking_move_to X54.40 Y9.40 Z88.00 Recv: > X54.40 Y9.40 Z-24.50 Recv: echo:busy: processing [...] Recv: echo:busy: processing [...] Recv: echo:busy: processing [...] Recv: echo:busy: processing [...] Recv: echo:busy: processing [...] Recv: echo:busy: processing [...] Recv: echo:busy: processing [...] Recv: echo:busy: processing [...] Recv: echo:busy: processing [...] Recv: echo:busy: processing [...] Recv: echo:busy: processing Recv: <<< do_blocking_move_to X54.40 Y9.40 Z-24.50 Recv: current_position= X54.40 Y9.40 Z4.04 : sync_plan_position Recv: <<< Probe::probe_down_to_z X54.40 Y9.40 Z4.04 Recv: FAST Probe fail! - Triggered early. Recv: <<< Probe::run_z_probe X54.40 Y9.40 Z4.04 Recv: current_position= X54.40 Y9.40 Z4.04 : Probe::set_deployed Recv: deploy: 0 Recv: >>> do_blocking_move_to X54.40 Y9.40 Z4.04 Recv: > X54.40 Y9.40 Z4.04 Recv: <<< do_blocking_move_to X54.40 Y9.40 Z4.04 Recv: Errorrobing Failed Changing monitoring state from "Operational" to "Error" Send: M112
#define Z_MIN_PROBE_ENDSTOP_INVERTING false // Set to true to invert the logic of the probe. #define FIX_MOUNTED_PROBE #define AUTO_BED_LEVELING_BILINEAR #define RESTORE_LEVELING_AFTER_G28 #define PROBING_MARGIN 20 #define NOZZLE_TO_PROBE_OFFSET { -34.4, 10.6, 3.7 } #define MULTIPLE_PROBING 2 #define GRID_MAX_POINTS_X 7 #define GRID_MAX_POINTS_Y GRID_MAX_POINTS_X #define Z_CLEARANCE_DEPLOY_PROBE 10 // Z Clearance for Deploy/Stow #define Z_CLEARANCE_BETWEEN_PROBES 5 // Z Clearance between probe points #define Z_CLEARANCE_MULTI_PROBE 5 // Z Clearance between multiple probes #define Z_PROBE_LOW_POINT -20 #define Z_PROBE_OFFSET_RANGE_MIN -20 #define Z_PROBE_OFFSET_RANGE_MAX 20 #define XY_PROBE_FEEDRATE (133*60) #define Z_PROBE_FEEDRATE_FAST (4*60) #define Z_PROBE_FEEDRATE_SLOW (Z_PROBE_FEEDRATE_FAST / 2) #define Z_SAFE_HOMING
Re: Printer halts at first Z-probe attempt April 11, 2022 04:44PM |
Re: Printer halts at first Z-probe attempt April 11, 2022 05:03PM |
Re: Printer halts at first Z-probe attempt April 11, 2022 08:29PM |
Re: Printer halts at first Z-probe attempt April 11, 2022 09:24PM |
Re: Printer halts at first Z-probe attempt April 11, 2022 09:55PM |
Re: Printer halts at first Z-probe attempt April 12, 2022 07:41AM |
lmcbmai
I have z-probe of my own design with optical sensor and electronic circuit identical to the circuits of X, Y and Z end-stops.
#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN #define FIX_MOUNTED_PROBE
Re: Printer halts at first Z-probe attempt April 13, 2022 02:09AM |
early_fail = (scheck && current_position.z > -offset.z + clearance); // Probe triggered too high?
