Marlin BF 2.1.2
Hi, I have a 300mm bed that runs mains voltage. I decided to run a temperature test on the printers and this one is off by about 12% low. I am using the bed-OEM recommended Marlin number 11 thermistor.
It is virtually impossible to replace the thermistor in the bed, so I am wondering if there is a temp-offset in Marlin somewhere that I can set for a 12% increase.
I know I can adjust the temp in the slicer so that 60 becomes 72, but I use the same profiles for other printers and would like to have the offending one carry the error adjustment.
Possible?
Thanks
