Your looking at old out of date information.
Dual axis is now enabled by enabling the appropriate stepper drivers, you don't manfully set NUM_Z_STEPPER_DRIVERS
Eg #define Z2_DRIVER_TYPE A4988
And that is it
Now if you want dual z endstops also you need to configure #define Z_MULTI_ENDSTOPS In Configuration_adv.h
Note you will get this warning "Note: Auto-assigned Z2 STEP/DIR/ENABLE_PINs to unused En_STEP/DIR/ENABLE_PINs. (Define NO_AUTO_ASSIGN_WARNING to suppress this warning.)"
You can either ignore it, or add #define NO_AUTO_ASSIGN_WARNING to suppress the warning
Edited 1 time(s). Last edit at 09/14/2023 08:53PM by Dust.
