Marlin firmware is not "RepRapFirmware" that is different firmware..
you should not use 1/256 mirco stepping all that does is bog down your controller with generating millions of unneeded step pules.
Use 1/16 with INTERPOLATE enabled.
The micro controller sees 1/16 but the stepper driver up scales to 1/256 internally. The driver then takes 16/256 steps for every 1/16th step input.
Edited 3 time(s). Last edit at 10/15/2023 08:42PM by Dust.
