4.2.7 config problem
Posted by Bazzer
December 04, 2023 12:55PM
Ender 5 pro, swapped board to 4.2.7, fitted CR touch, downloaded Marlin bugfix 2.0.x firmware and config examples, started to carry out modifications to firmware using VSC, everything good until choosing listed config for the 4.2.7 board, the board I have has a T5 sticker instead of marker pen code on the card cover ! my board has a STM32F103RET6 chip which is not listed in the config file, it only has RF type listed, I have spent hours searching for answers and trying to solve but no joy....can anyone help please ?
Re: 4.2.7 config problem
December 04, 2023 07:54PM
That doesn't make sense, I have no idea where or what your referring to with RF
In Configuration.h you set #define MOTHERBOARD BOARD_CREALITY_V427
If using Auto build marlin your presented with a menu
STM32F103RC_creality
STM32F103RC_creality_xfer
STM32F103RE_creality
STM32F103RE_creality_xfer
STM32F103RE_creality_maple
You click the one that matches your STM32F103RE with any options you may want
The T6 in the chip name is the plastic used around the chip and its temperature range, so it is not used in marlin.
If you not using auto build marlin you update platformio.ini
Set the line default_envs = mega2560 chnage it to = one of the environments listed above.
eg default_envs = STM32F103RE_creality
The T5 sticker means your board has TMC2225 so you should set driver type to TMC2208_STANDALONE
Edited 6 time(s). Last edit at 12/04/2023 09:21PM by Dust.
