Motoren verplaatsen via menu (mks robin nano v3.1)
Posted by edensan
December 25, 2023 04:04PM
Hello all,
i want to move the axis via the printer's menu.
1 axis works fine, so either y or x or z
after this i have to switch off the motors before i can operate another axis.
so for example i do z up after this I HAVE TO SWITCH OFF THE MOTORS .
then i can, for example, move y axis, after which I HAVE TO SWITCH OFF THE MOTORS .
then i can, for example, move x axis after this... and so on
I also cant move two axis on same time then i hear a clicking sound and the green light on the driver start blinking
anyone have any ideas how i can solve this?
# define DISABLE_X true is not an option because then i might lose position.
greetings edensan
Edited 1 time(s). Last edit at 12/25/2023 04:40PM by edensan.
Re: Motoren verplaatsen via menu (mks robin nano v3.1)
December 26, 2023 02:11AM
What power supply are you using? Perhaps it can't supply enough current to drive more than one motor at a time.
December 26, 2023 03:30AM
Ik i use two powersupplies 1 for nano 460 watt pc powersupply and for nema 23 motors a old bike charge powersupply 40V 2 Amp.
I thought it is mor then annough
Greetz Edwin
December 26, 2023 04:12AM
Changed power supply problem solved i use old laptop powersupply 20v 6 Amp
Thx!!
