Robin Nano v3.1 + 3Dtouch + SmartFilamentSensor, USB connection January 19, 2024 07:19PM |
Re: Robin Nano v3.1 + 3Dtouch + SmartFilamentSensor, USB connection January 20, 2024 05:47PM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Robin Nano v3.1 + 3Dtouch + SmartFilamentSensor, USB connection January 28, 2024 10:56AM |
// @section machine /** * Select the serial port on the board to use for communication with the host. * This allows the connection of wireless adapters (for instance) to non-default port pins. * Serial port -1 is the USB emulated serial port, if available. * Note: The first serial port (-1 or 0) will always be used by the Arduino bootloader. * * :[-1, 0, 1, 2, 3, 4, 5, 6, 7] */ #define SERIAL_PORT -1 /** * Serial Port Baud Rate * This is the default communication speed for all serial ports. * Set the baud rate defaults for additional serial ports below. * * 250000 works in most cases, but you might try a lower speed if * you commonly experience drop-outs during host printing. * You may try up to 1000000 to speed up SD file transfer. * * :[2400, 9600, 19200, 38400, 57600, 115200, 250000, 500000, 1000000] */ #define BAUDRATE 115200 //#define BAUD_RATE_GCODE // Enable G-code M575 to set the baud rate /** * Select a secondary serial port on the board to use for communication with the host. * Currently Ethernet (-2) is only supported on Teensy 4.1 boards. * :[-2, -1, 0, 1, 2, 3, 4, 5, 6, 7] */ //#define SERIAL_PORT_2 1 //#define BAUDRATE_2 250000 // Enable to override BAUDRATE /** * Select a third serial port on the board to use for communication with the host. * Currently only supported for AVR, DUE, LPC1768/9 and STM32/STM32F1 * :[-1, 0, 1, 2, 3, 4, 5, 6, 7] */ //#define SERIAL_PORT_3 1 //#define BAUDRATE_3 250000 // Enable to override BAUDRATE // Enable the Bluetooth serial interface on AT90USB devices //#define BLUETOOTH // Choose the name from boards.h that matches your setup #ifndef MOTHERBOARD #define MOTHERBOARD BOARD_MKS_ROBIN_NANO_V3 #endif
Re: Robin Nano v3.1 + 3Dtouch + SmartFilamentSensor, USB connection January 28, 2024 11:19AM |
