JPT
fine-tuning marlin,
February 04, 2024 11:53AM
I am currently fine-tuneing my Marlin 2.1.x-bugfix.zip build.
It's the Creality 32 bit board V 427 on the Creality CR-10S5 printer plus Creality BL touch sensor.
I've got several problems and cannot find solutions:
  • G26 C creates a pattern to test the auto-leveling. But it sends all my clamps flying that should hold the glass to the bed. This is because it prints 5 mm from the edge of the bed. I would like to leave at least 15 mm border. Why is there a "pause for user" after the mesh probing?
  • G29 J should check the tilt of the auto-leveling mesh but it does not seem to work. I accidentally moved one of the z axis motors which should have brought the mesh out of tune. After that I did a G28 then G29 J and now the G26 C does not work at all.
  • G29 J goes too near to the border as well and sometimes probes onto the clamps which makes the data wrong.
  • If I pause a print from the menu, then move the head away to see the print status. Then when I continue to print it just continues where the head is, not where it stopped printing. Is this normal behavior? Can I change it?
  • Before Home I would like to lift the head a little so it doesn't scrape over the bed or kick anything that's left on the bed.
  • Why does it ask "Click to resume" just after it finished preparation (home and heating) and should start printing? Is there a way to make it beep anytime it asks for user input?
And there is something wrong with the extruder.
During printing every few seconds it retracts for 5 or 10 mm with extremely high speed, then extrudes again slowly while printing.
This results in not printing anything at all, because it again retracts before it extruded the amount it retracted before.
I cannot see any problem in the gcode cura produced. It continuously increases the E-position.
G92 E0
G1 F2700 E-5
;LAYER_COUNT:1
;LAYER:0
M107
G0 F6000 X41.623 Y41.427 Z0.32
;TYPE: SKIRT
G1 F2700 E0
G1 F1200 X42.52 Y40.634 E0.12743
G1 X43.368 Y40.015 E0.23917
G1 X44.207 Y39.506 E0.34362
G1 X45.15  Y39.038 E0.45566
No, I was wrong: there is a retract:
G1 X42.785 Y42.527 E35.20947
G1 F2700 E30.20947
G0 F6000 X428.012 Y49.774
G1 F2700 E35.20947
G1 F1200 X428.078 Y48.726 E35.32123
but there is an extrude with the same speed afterward.
thank you
Edited 2 time(s). Last edit at 02/04/2024 12:28PM by JPT.
