Hi All,
Since a couple of weeks I'm running Marlin on one of my two Ender 3 Pros.
I would like to adjust the working of the encoder below the display.
If I want to heat the nozzle to change the filament or setup z-probe distance I have to turn all the way from 0 to over 200 degrees.
When the filament is pulled I have to turn the other way all the way down to 0.
I there a way in Marlin to adjust this to:
(When going up)
0 to 190, then 191, 192 etc
(When going down)
From the set temperature to (set temp -1), (set temp -2) down to 190 and from 190 directly to 0
This would save a lot of unnecessary turning on the encoder.
