See the diagram in the config
* Assuming the typical work area orientation:
* - Probe to RIGHT of the Nozzle has a Positive X offset
* - Probe to LEFT of the Nozzle has a Negative X offset
* - Probe in BACK of the Nozzle has a Positive Y offset
* - Probe in FRONT of the Nozzle has a Negative Y offset
* Some examples:
* #define NOZZLE_TO_PROBE_OFFSET { 10, 10, -1 } // Example "1"
* #define NOZZLE_TO_PROBE_OFFSET {-10, 5, -1 } // Example "2"
* #define NOZZLE_TO_PROBE_OFFSET { 5, -5, -1 } // Example "3"
* #define NOZZLE_TO_PROBE_OFFSET {-15,-10, -1 } // Example "4"
* +-- BACK ---+
* L | 1 | R <-- Example "1" (right+, back+)
* E | 2 | I <-- Example "2" ( left-, back+)
* F |[-] N [+]| G <-- Nozzle
* T | 3 | H <-- Example "3" (right+, front-)
* | 4 | T <-- Example "4" ( left-, front-)
* O-- FRONT --+
This diagram presumes your X0,Y0 is standard front left. of the bed. (ie the O meaning origin point)
"#define NOZZLE_TO_PROBE_OFFSET { 16, 33, 1 }"
"When I'm in front of the Printer the Z-Probe is behind and left to the nozzle so the values are positive (?)."
Yes and no, one of each
Presuming your measurements are correct
left of nozzle is - ie -16
behind the nozzle is positive ie 33
Also your Z value says your probe point is higher than your hotend by 1mm, so to probe you dig the hotend into the bed by 1mm...
Edited 1 time(s). Last edit at 03/26/2024 03:32AM by Dust.
