Duet problems...
February 12, 2016 01:52PM
I've got a pair of Duet 0.8.5 boards I'm having problems with.
Board #1 has the 1.09b firmware (as I received it) and it won't come up on the network - the only change I've made to config.g is setting the ip address, gateway & netmask for my internal network. The board doesn't respond to pings nor does it's MAC address appear in my router. Webserver doesn't respond on the address I specified (10.1.10.6 for the host 10.1.10.1 for the gateway and 255.255.255.0 for the netmask)
Board #2 has been upgraded to 1.09r but cannot read the configuration file for whatever reason - the file IS present in the sys directory.
Here's the output on boot:
RepRapFirmware Version 1.09r-dc42 dated 2016-01-16
Executing default.g (no configuration file found)... Error, not found
RepRapFirmware is up and running.
Starting network...
Network up, IP=192.168.1.10
This board doesn't appear on my network either. (no MAC address showing in the router, no ping response, no browser response.)
I do not have a PanelDue installed and have no plans to install one.
Suggestions?
tnx.
g.
Re: Duet problems...
February 12, 2016 03:25PM
Sorry for the noise - a new SD card and the board was happy. I'll try re-formatting the old one to see if it works.
g.
