Duet 0.8.5 - Delta Kossel - XYZ Calibration
March 28, 2016 09:15AM
Hello fellow RepRap(ers?)!
I have upgraded from a RAMPS 1.4 board that I had been using for a long time and had calibrated to be extremely accurate (10mm cubes perfect all the way up to 40mm cubes). I then decided to take the plunge and buy myself some new upgrades - pretty much all from Think3DPrint3D including the Duet 0.8.5 board and new Carbon fibre rods with Traxxas ends.
I have been running through my fine tuning now but have come across a weird scenario on my X and Y axis. Basically I noticed that my prints were not being printed in the correct dimensions - so the first place I looked was the axis steps/mm and noticed that I had accidently left the original value of 80 untouched. I updated this with the value I required based on GT2 belt with 2mm pitch, 16 tooth pulley, 1.8' motor step angle and 1/16 micro-stepping giving me a value of 100 steps/mm (confirmed with the RepRapCalculator).
Now when I print a 10mmx10mmx10mm calibration cube I get lengths of 10.25mm on both X and Y axis however my Z axis is absolutely perfect at 10mm? Could anyone point me in the right direction of what I should look at calibrating next please?
Other notes:
I did notice that my diagonal rod length was out by 0.5mm so I corrected this by updating the value in my configuration - All rods were pre-assembled by the folks at Think3DPrint3D on their Jig and they are all the same length from centre hole to centre hole.
This is the first time that I have ever used the M666 end stops for levelling configuration as I would usually have gone through the more painful process of manually tuning the bed levelling with my Allen key - to be honest it was pretty close to spot on before I started with the M666 calibration.
For reference here is a copy of my configuration file as it is right now.
Thank you for reading!
; Configuration file for Mini Kossel kit from Think3DPrint3D
; Communication and general
M111 S0                             ; Debug off
M550 PMiniKossel		        	; Machine name and Netbios name (can be anything you like)
M551 Preprap                        ; Machine password (used for FTP)
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
;*** Adjust the IP address and gateway in the following 2 lines to suit your network
;***M552 P0.0.0.0						; IP address (0 = use DHCP)
M552 P192.168.1.115	; Static IP address for home network
M554 P192.168.1.1                   ; Gateway
M553 P255.255.255.0                 ; Netmask
M555 P2                             ; Set output to look like Marlin
M575 P1 B57600 S1					; Comms parameters for PanelDue
G21                                 ; Work in millimetres
G90                                 ; Send absolute coordinates...
M83                                 ; ...but relative extruder moves
; Axis and motor configuration
M569 P0 S1							; Drive 0 goes forwards
M569 P1 S1							; Drive 1 goes forwards
M569 P2 S1							; Drive 2 goes forwards
M569 P3 S0							; Drive 3 goes forwards
M569 P4 S0							; Drive 4 goes backwards (not forwards)
M574 X2 Y2 Z2 S1					; set endstop configuration (all endstops at high end, active high)
;*** The homed height is deliberately set too high in the following - you will adjust it during calibration - OLD 320.15
M665 R123.83 L215.5 B80 H256.61			; set delta radius, diagonal rod length, printable radius and homed height
M666 X-3.65 Y-2.80 Z-1.85						; put your endstop adjustments here, or let auto calibration find them
M92 X100 Y100 Z100						; Set axis steps/mm
M906 X1000 Y1000 Z1000 E600 I60		; Set motor currents (mA) and increase idle current to 60%
M201 X1000 Y1000 Z1000 E1000		; Accelerations (mm/s^2)
M203 X20000 Y20000 Z20000 E3600		; Maximum speeds (mm/min)
M566 X1200 Y1200 Z1200 E1200		; Maximum instant speed changes mm/minute
; Thermistors
;*** If you have a Duet board stickered "4.7K", change R1000 to R4700 to the following M305 commands
M305 P0 T100000 B3950 R4700 H30 L0	; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 T100000 B3974 R4700 H30 L0	; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
M305 P2 T100000 B3974 R4700 H30 L0	; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
M570 S180							; Hot end may be a little slow to heat up so allow it 180 seconds
; Tool definitions
M563 P0 D0 H1                       ; Define tool 0
G10 P0 S0 R0                        ; Set tool 0 operating and standby temperatures
;*** If you have a dual-nozzle build, un-comment the next 2 lines
;M563 P1 D1 H2                      ; Define tool 1
;G10 P1 S0 R0                       ; Set tool 1 operating and standby temperatures
M92 E152:152                       	; Set extruder steps per mm
; Z probe and compensation definition
;*** If you have an IR zprobe instead of a switch, change P4 to P1 in the following M558 command
M558 P4 X0 Y0 Z0					; Z probe is a switch and is not used for homing any axes
G31 X0 Y0 Z4.80 P500				; Set the zprobe height and threshold (put your own values here)
;*** If you are using axis compensation, put the figures in the following command
M556 S78 X0 Y0 Z0                   ; Axis compensation here
M208 S1 Z-0.2						; set minimum Z
T0									; select first hot end
Re: Duet 0.8.5 - Delta Kossel - XYZ Calibration
March 28, 2016 11:54AM
A few things to check:
1. Make sure that the diagonal rod length, measured between the bearing centres, is configured accurately in the firmware (M665 L parameter).
2. Make sure the spacing between bearings is the same on the carriages as on the effector. A difference will cause the effector to tilt as it translates, which will affect the scaling.
3. To test the scaling accurately, you need to use a cube much larger than 10mm so that under/over extrusion has less effect.
4. If all else fails, you can use the M579 command to adjust the XY scaling, see [reprap.org]. But it is better to fix your machine geometry, otherwise you may find the scaling varies depending on where on the bed you print your cube.
March 28, 2016 01:22PM
Thanks for the quick response dc42! Here are the results:
dc42
1. Make sure that the diagonal rod length, measured between the bearing centres, is configured accurately in the firmware (M665 L parameter). I can confirm that this is correct
2. Make sure the spacing between bearings is the same on the carriages as on the effector. A difference will cause the effector to tilt as it translates, which will affect the scaling. I can confirm that both the spacing on the carriages and effector are at 40mm
3. To test the scaling accurately, you need to use a cube much larger than 10mm so that under/over extrusion has less effect.Good suggestion - I will print a new 40mm cube now and report back on the results
Let hope it doesn't come to this - I will do everything to make sure that this is mechanically correct!
Thank you for your suggestions and assistance.
March 29, 2016 09:22AM
After racking my brain as to why this may be occurring I went back to basics and re-ran all of the calibration steps from your fantastic article Mini Kossel Calibration.
It's worth stating that this is the original article that I had followed - however it must have been late in the day as my new M665 values are as follows - you can see a significant difference in the delta radius settings and my updated diagonal rod measurements here:
Old M665 setting:
New M665 setting:
M665 R110.95 L215.5 B80 H259.80			; set delta radius, diagonal rod length, printable radius and homed height
Just look at the difference in the delta radius setting! This must have impacted the scaling somewhat?
Now I am going to move onto the next piece of calibration - my extruder. Looks like its skipping (luckily not chewing the filament as I have the current low). Are these the correct 3 areas to be looking at calibrating:
  1. Recalibrate Extruder Steps per mm based on Triffid Hunters Cal Guide
  2. Ensure the current setting on M906 is sufficient - fine tune until just before grinding
  3. Fine tune temp for E3Dv6 hotend (smaller heat chamber = higher temp required @ higher speeds)
March 29, 2016 10:15AM
Results from new 40mmx40mmx40mm calibration cube as promised
X and Y axis are now measuring at 39.99mm and the Z axis is measuring at 40mm! I think that will be sufficiently accurate! Off to print some awesome things that I probably don't even need spinning smiley sticking its tongue out
Thank you dc42
