[SOLVED] Updated fw, now z-probe is inverted? April 13, 2016 08:55AM |
; Ormerod 2 config file for dc42 Duet firmware M111 S0 ; Debug off M550 PMy Ormerod 2 ; Machine name (can be anything you like) M551 Preprap ; Machine password (currently not used) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address ;*** Adjust the IP address and gateway in the following 2 lines to suit your network M552 P10.83.10.215 ; IP address (0 = use DHCP) M554 P10.83.10.1 ; Gateway M553 P255.255.255.0 ; Netmask M555 P2 ; Set output to look like Marlin M575 P1 B57600 S1 ; Comms parameters for PanelDue G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M574 X0 Y1 Z0 S1 ; set endstop configuration (Y endstop only, at low end, active high) M92 X87.4890 Y87.4890 Z4000 ; Set axis steps/mm M906 X800 Y1000 Z1000 E800 ; Set motor currents (mA) M563 P0 D0 H1 ; Define tool 0 G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures M92 E424 ; Set extruder steps per mm (single nozzle) ;*** If you have a dual-nozzle build, remove or comment out the previous line, and un-comment the following 3 lines ;M563 P1 D1 H2 ; Define tool 1 ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures ;M92 E420:420 ; Set extruder steps/mm (dual nozzle) ;*** If you have a modulated IR probe with on-board microcontroller, change P2 to P1 in the following M558 P2 ; Use a simple modulated Z probe (change to P1 for an intelligent Z probe) G31 Z2.0 P595 ; Set the probe height and threshold (put your own values here) ;*** If you have a Duet board with 1K thermistor series resistors, change R4700 to R1000 to the following M305 commands M305 P0 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction M305 P1 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction M305 P2 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the IR sensor M557 P0 X60 Y0 ; Four... M557 P1 X60 Y165 ; ...probe points... M557 P2 X222 Y165 ; ...for bed... M557 P3 X222 Y0 ; ...levelling ;M557 P4 X141 Y82.5 ; 5th probe point for levelling (un-comment this if you are using a dc42 differential IR probe) ;*** if you are using axis compensation, put the figures in the following command M556 S80 X0 Y0 Z-0.5 ; Axis compensation here M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min) M566 X600 Y600 Z30 E20 ; Minimum speeds mm/minute M208 X214 Y210 Z200 ; set axis maxima (adjust to suit your machine) M208 X-8 Y0 Z-1 S1 ; set axis minimum (adjust to make X=0 the edge of the bed) ; T0 ; select first hot end
M122 Diagnostics Used output buffers: 4 of 16 (15 max) Platform Diagnostics: Memory usage: Program static ram used: 42104 Dynamic ram used: 39688 Recycled dynamic ram: 128 Current stack ram used: 2712 Maximum stack ram used: 5396 Never used ram: 10988 Last reset 00:40:06 ago, cause: software Last software reset code & available RAM: 0x0003, 10484 Spinning module during software reset: GCodes Error status: 0 Bed probe heights: 0.616 -0.245 -1.074 0.703 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 Free file entries: 9 Longest block write time: 462.5ms Slowest main loop (seconds): 0.463837; fastest: 0.000000 Move Diagnostics: MaxReps: 4, StepErrors: 0 Heat Diagnostics: GCodes Diagnostics: Move available? no Stack pointer: 0 of 5 Network Diagnostics: Free connections: 15 of 16 Free transactions: 23 of 24 Webserver Diagnostics: HTTP sessions: 1 of 8 FTP connections: 0, state 0 Telnet connections: 0
G32 Bed equation fits points [60.0, 0.0, 0.616] [60.0, 165.0, -0.245] [222.0, 165.0, -1.074] [222.0, 0.0, 0.703] M32 Cable_Spool-_low_A_100%.gcode File Cable_Spool-_low_A_100%.gcode selected for printing Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault M0 H1 Printing paused Print cancelled
Re: Updated fw, now z-probe is inverted? April 13, 2016 06:40PM |
Re: Updated fw, now z-probe is inverted? April 14, 2016 03:49AM |
dc42
Hi, and thanks for trying my fork.
1. The Z probe reading always has got higher the closer to the bed it is - except when it is very close to the bed, when it may start going down again.
2. Whether the machine waits for the hot end to heat up or not at the start of a print depends on what you have in your slicer start gcode. So we need to see the start of the gcode file you are trying to print to diagnose the problem.
G28 ; home all axes M83; G10 P0 S195 R160 ; Set tool 0 operating and standby temperatures T0
G1 X2 Y190 F9000 G4 S0 G10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures M140 S40
; generated by Slic3r 1.2.9 on 2016-04-13 at 14:19:05 ; external perimeters extrusion width = 0.50mm ; perimeters extrusion width = 0.50mm ; infill extrusion width = 0.50mm ; solid infill extrusion width = 0.50mm ; top infill extrusion width = 0.50mm M107 M190 S57 ; set bed temperature G28 ; home all axes M83; G10 P0 S195 R160 ; Set tool 0 operating and standby temperatures T0 G21 ; set units to millimeters G90 ; use absolute coordinates M83 ; use relative distances for extrusion G1 E-3.50000 F2400.00000 G1 Z0.300 F9000.000 G1 X65.465 Y65.908 F9000.000 G1 E3.50000 F2400.00000 G1 X67.813 Y63.684 E0.29682 F1200.000 G1 X70.519 Y61.456 E0.32155 G1 X73.604 Y59.282 E0.34628 ...
Re: Updated fw, now z-probe is inverted? April 14, 2016 06:03PM |
Re: Updated fw, now z-probe is inverted? April 15, 2016 05:36AM |
Re: Updated fw, now z-probe is inverted? April 15, 2016 06:18PM |
