Auto Calibration with Parameter S6 May 24, 2016 05:18AM |
Re: Auto Calibration with Parameter S6 May 24, 2016 02:05PM |
Re: Auto Calibration with Parameter S6 May 25, 2016 03:02AM |
Re: Auto Calibration with Parameter S6 May 25, 2016 12:09PM |
critical_limit
Thanx David,
I already checked all this and can´t find a fault.
What I don´t understand is, that all Dimensions are ok exept Y-Direction.
Also I have no answer to this autocalibration thing. Why autocal is making the delta crooked?
Manuelly set X, Y, Z to zero in M665 is resulting in 90° angels which is perfect and tells me my Delta is well built.
Autocal is setting X and Y to a value where X to Y angles are out of 90°. Don´t understand.
But will recheck all again. But I don´t understand why autocal is doing this.
Is M579 for Delta Printers also? Wiki says its for cartensian printers. So I was thinking X, Y, Z Values in M579 are for the physical axis?!
Re: Auto Calibration with Parameter S6 May 26, 2016 10:36AM |
Re: Auto Calibration with Parameter S6 May 26, 2016 04:48PM |
critical_limit
Thanx Pierre.
I Think I´ve dialed it in now.
Calibrating with S4 giving the best results for me. My Testboxes are now rectangular and I used the M579 Y1.02 to correct the Y-Direction fault.
First Layer is a dream now. Before it was good, but due to calibrating with S6 it has some minor issues. Never thought about that S6 is giving values for X Y Z in M665 so far away from reality.
Actually I´m printing a technical Part (Effectorplatform for magnetic ballarms) that I never managed to hold dimensions as designed. I´m really curious if it will work now.
Thanx to all for helping me out!
cheers
Dirk
