Interested in duet, some info needed May 30, 2016 05:12PM |
Re: Interested in duet, some info needed May 30, 2016 06:44PM |
Re: Interested in duet, some info needed May 30, 2016 07:04PM |
Re: Interested in duet, some info needed May 31, 2016 02:18AM |
dc42
I see that bltouch needs 5V power, which the Duet can provide; but does it also need a 5V control signal? The control signals on the Duet are 3.3V (as on most 32-bit boards). I suspect that bltouch may need additional firmware support.
HTH David
PRZ
The BLtouch is an interesting idea, notably because it will be quite insensitive to temperature.
There is a demo with Smoothie, so I suppose it does accept 3.3V signal.
It is told that it uses the same signal as an RC servo, then it qualifies this signal as PWM, while servo signal are not PWM, but specific signals. The time diagram is not clear, so I think some questions shall be asked to the designers. And it most probably needs additional firmware.
BLTouch uses the same servo signal which used in previous servo line.
■ Solenoid Push-pin Up ➡ servo signal 90Degree(ex : M280 P0 S90 ) ← PWM
■ Solenoid Push-pin Down ➡ servo signal 10Degree(ex : M280 P0 S10 )
■ Manual Self-test ➡ servo signal 120Degree(ex : M280 P0 S120)
■ Alarm Release ➡ servo signal 160Degree(ex : M280 P0 S160)
※ BLTouch can be operated in the following condition.
- One PWM (or Software PWM) for control
- One I/O for Zmin
- GND and +5V power
However, Firmware updating might be needed on a case.
PRZ
Just a note about Duet 0.6. From user viewpoint, it works like the Duet 0.8.5 (I have both) but you have more possibilities of extensions on the 0.8.5. Even if you don't want a second extruder, its associated hardware could be used for a chamber heater, or another temperature control on the hotend, or an ambient temperature control.
You can use the second controlled fan to cool the hotend instead of having a fixed fan (while some prefer to have fixed voltage fan for the hotend for safety reasons - thats include me).
In that hobby, you always do unplanned things.
And there may be not many genuine 0.6 still on sale (the remaining stock of RepRapPro).
Re: Interested in duet, some info needed May 31, 2016 06:51AM |
Re: Interested in duet, some info needed May 31, 2016 07:19AM |
Re: Interested in duet, some info needed May 31, 2016 07:26AM |
Re: Interested in duet, some info needed May 31, 2016 07:40AM |
Re: Interested in duet, some info needed May 31, 2016 07:47AM |
Re: Interested in duet, some info needed June 26, 2016 07:02AM |
Re: Interested in duet, some info needed June 26, 2016 07:56AM |
