"Attempt to move the head of a delta printer before homing the towers" May 31, 2016 03:28PM |
Attempt to move the head of a delta printer before homing the towers.
Re: "Attempt to move the head of a delta printer before homing the towers" May 31, 2016 04:07PM |
Re: "Attempt to move the head of a delta printer before homing the towers" May 31, 2016 04:16PM |
; Homing file for RepRapFirmware on Mini Kossel
G91 ; use relative positioning
;******* Change F250 in the following line to F2500 when you are finished commissioning
;******* Change 320 in the following to a higher value if your Kossel has taller towers
G1 S1 X420 Y420 Z420 F10000 ; move all carriages up 420mm, stopping at the endstops
G1 S2 X-3 Y-3 Z-3 ; move all carriages down 3mm
G1 S1 X6 Y6 Z6 F250 ; move carriages slowly up 6mm, stopping at the endstops
G1 Z-5 F2000 ; down a few mm so that we can centre the head
G90 ; back to absolute positioning
G1 X0 Y0 F5000 ; centre the head and set a reasonable feed rate
Re: "Attempt to move the head of a delta printer before homing the towers" May 31, 2016 05:26PM |
Re: "Attempt to move the head of a delta printer before homing the towers" May 31, 2016 05:38PM |
Re: "Attempt to move the head of a delta printer before homing the towers" May 31, 2016 08:09PM |
Re: "Attempt to move the head of a delta printer before homing the towers" June 01, 2016 10:10AM |
Re: "Attempt to move the head of a delta printer before homing the towers" June 01, 2016 11:50AM |
Re: "Attempt to move the head of a delta printer before homing the towers" June 01, 2016 12:47PM |
maso
I've checked the ref voltages and used M906 to change them, which seems to work.
X-ref is a lot lower than the others. With M906 800 I see ~.4V on most, ~.1 on X.
When I get back to the printer today I plan to check if I'm seeing activity on enable and step.
Re: "Attempt to move the head of a delta printer before homing the towers" June 01, 2016 07:02PM |
Re: "Attempt to move the head of a delta printer before homing the towers" June 20, 2016 11:11AM |
Re: "Attempt to move the head of a delta printer before homing the towers" June 20, 2016 12:36PM |
maso
As a follow-up:
I got a new Duet board and replaced my old one. Everything works great again!
I don't know what failed, but it appears to have been a hardware issue, not a firmware one. The original error "Attempt to move the head of a delta printer before homing the towers" was due to the motors not moving at all, and the home process timing out without triggering the endstops.
