Duet 0.8.5 and G32 not adjusting? - FIXED! June 26, 2016 05:52PM |
Bed equation fits points [30.0, 10.0, -0.107] [30.0, 130.0, -0.257] [170.0, 130.0, 0.393] [170.0, 10.0, 0.355]
T0 G21; set units to millimeters M190 S[first_layer_bed_temperature]; set bed temperature and wait for temperature G10 P0 S[first_layer_temperature_0] R160; Set tool 0 operating and standby temperatures M109 S[first_layer_temperature_0]; Set tool 0 operating temperature and wait for temperature G28 ; home X and Y and Z G32 ; Probe Z and calculate Z plane M83 ; Set extruder to relative mode
; The following M557 commands are not needed if you are using a bed.g file to perform bed compensation ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the Z probe M557 P0 X30 Y10 ; Four... M557 P1 X30 Y130 ; ...probe points... M557 P2 X170 Y130 ; ...for bed... M557 P3 X170 Y10 ; ...levelling ;M557 P4 X100 Y100 ; 5th probe point for levelling
; Tool definition M563 P0 D0 H1 ; Define tool 0 G10 P0 S0 R0 X0 Y0 ; Set tool 0 operating and standby temperatures ;*** If you have a dual-nozzle build, un-comment the following 3 lines ;M563 P1 D1 H2 ; Define tool 1 ;G10 P1 S0 R0 X0 Y0 ; Set tool 1 operating and standby temperatures M143 S275 ; Define Maximum hot-end temperature ; Z probe ;M558 P1 X0 Y0 Z1 ; Analog Z probe, also used for homing the Z axis ;G31 Z1.20 P500 ; Set the probe height and threshold (put your own values here) M558 P1 X0 Y0 Z1 H3 F200 T5000 ; smart IR Z probe, used for homing Z axis only, dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min G31 P500 X0.0 Y0.0 Z0.52 ; set threshold and offsets ;*** If you are using axis compensation, put the figures in the following command M556 S78 X0 Y0 Z0 ; Axis compensation here
Re: Duet 0.8.5 and G32 not adjusting? June 26, 2016 06:08PM |
Re: Duet 0.8.5 and G32 not adjusting? June 26, 2016 06:26PM |
Re: Duet 0.8.5 and G32 not adjusting? June 26, 2016 10:32PM |
Bed equation fits points [30.0, 10.0, -0.005] [30.0, 130.0, -0.180] [170.0, 130.0, 0.420] [170.0, 10.0, 0.420]
Re: Duet 0.8.5 and G32 not adjusting? June 27, 2016 06:02AM |
PDBeal
So after moving the head around to my 4 points and adjusting the 3 leveling spring screws, it triggers the Z probe around 0.60-0.63 for all 4 corners. I kept moving Z to 10, then doing G30 S-1 to get a distance on each corner. Sometimes they report 0.61 other times it reports 0.60 depending on the corner and other corners with no screw seem to report 0.62-0.63. At this point I think this is the accuracy of the differential IR probe reading my MK2b heatbed through a piece of glass? With this setup, G32 should offset the Z plane? Or do I need to get them even closer still?
After this setup, I then re-calibrated the Z offset for the differential IR sensor with the hot end at 240C. Loaded up the same print and the same rear corner (30,130) was squashed. I got the following message in the G-Code Console
But I do not see the Z axis moving whatsoever during the print (outside of layer changes and retraction). Oddly enough the corner that is squashed is the left side of the single screw/spring side with the screw being in the middle. If it matters, I'm running 1.13b firmware on the 0.85 Duet. Am I missing something with my calibration, or is something not quite right somewhere?
Re: Duet 0.8.5 and G32 not adjusting? June 27, 2016 09:31AM |
Re: Duet 0.8.5 and G32 not adjusting? June 27, 2016 12:42PM |
Re: Duet 0.8.5 and G32 not adjusting? June 27, 2016 01:24PM |
Re: Duet 0.8.5 and G32 not adjusting? June 27, 2016 03:11PM |
Re: Duet 0.8.5 and G32 not adjusting? June 27, 2016 03:40PM |
Re: Duet 0.8.5 and G32 not adjusting? June 27, 2016 03:47PM |
Re: Duet 0.8.5 and G32 not adjusting? June 27, 2016 09:31PM |
