Last reset xx:xx:xx ago, cause: watchdog August 03, 2016 03:15PM |
M122
Last reset 00:05:52 ago, cause: watchdog
M122
Diagnostics
Used output buffers: 4 of 32 (8 max)
Platform Diagnostics:
Memory usage:
Program static ram used: 45208
Dynamic ram used: 40296
Recycled dynamic ram: 512
Current stack ram used: 2744
Maximum stack ram used: 5612
Never used ram: 6676
Error status: 0
Bed probe heights: 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000
Free file entries: 10
SD card interface speed: 21.0MBytes/sec
SD card longest block write time: 0.0ms
MCU temperature: min 43.7, current 56.5, max 73.2
Slowest main loop (seconds): 0.059906; fastest: 0.000183
Move Diagnostics:
MaxReps: 3, StepErrors: 0. Underruns: 0
Heat Diagnostics:
Bed heater = 0, chamber heater = -1
Heater 0 is on, I-accum = 57.7
Heater 1 is on, I-accum = 98.5
GCodes Diagnostics:
Move available? no
Stack pointer: 0 of 5
macro is idle
http is ready with "M122"
telnet is idle
serial is idle
aux is idle
file is idle
Network Diagnostics:
Free connections: 15 of 16
Free transactions: 23 of 24
Webserver Diagnostics:
HTTP sessions: 1 of 8
FTP connections: 0, state 0
Telnet connections: 0, state 0
Re: Last reset xx:xx:xx ago, cause: watchdog August 03, 2016 03:43PM |
Re: Last reset xx:xx:xx ago, cause: watchdog August 03, 2016 05:49PM |
Re: Last reset xx:xx:xx ago, cause: watchdog August 06, 2016 01:41PM |
Re: Last reset xx:xx:xx ago, cause: watchdog August 06, 2016 05:53PM |
n8bot
It's possible that the machine reset with a static electricity discharge from me. It's dry here and sometimes I electrocute everything and everyone I touch, and I've had discharges into the nozzle cause resets before. Would this be reported as a watchdog reset?
Re: Last reset xx:xx:xx ago, cause: watchdog August 06, 2016 10:33PM |
