Trying to get a printer wired up and right now was working on getting the extruder wired up. I have it connected to the E0 connections for the heater and thermistor. I have check the wiring and verified the thermistor connection is making it to the board's connector. However, DWC is reporting an error for the heater. I have tried both the E0 and E1 connections with the same results (with appropriate tool definitions). Any suggestions on what to try next?
Duet 0.8.5
Firmware 1.14
DWC 1.11
P.S. Yes, I know there is a newer version of the firmware and not ready to upgrade to it yet.
EDIT: Fixed the problem. Was a bad connector. It wasn't making a connection with the board when plugged in.
Edited 1 time(s). Last edit at 09/03/2016 07:08PM by ElmoC.
