I am having a horrible time with the DUET. I have had no issues this weekend with setting up the probe. The probe never hit the bed. Today, while I am still trying to get my first print, now when I do home all or home Z, it moves the bed, I see the probe value change from 0 to my target of 940. It slows down and then continues to move until it hits the bed and I have to shut the printer off to kill the movement. Here is my conifg file.
CoreXY sample config file for dc42 Duet firmware
M111 S0 ; Debug off
M550 Pprinter ; Machine name (can be anything you like)
M551 Preprap ; Machine password (used for FTP connections)
M540 P0xBE: MAC Address
;*** Adjust the IP address and gateway in the following 2 lines to suit your network
M552 P192.168.25.75 ; IP address (0 = use DHCP)
M554 P192.168.25.1 ; Gateway
M553 P255.255.255.0 ; Netmask
M555 P2 ; Set output to look like Marlin
M575 P1 B57600 S1 ; Comms parameters for PanelDue
G21 ; Work in millimetres
G90 ; Send absolute coordinates...
M83 ; ...but relative extruder moves
; Machine configuration
M569 P0 S1 ; Drive 0 goes forwards (change to S0 to reverse it)
M569 P1 S0 ; Drive 1 goes forwards
M569 P2 S1 ; Drive 2 goes forwards
M569 P3 S1 ; Drive 3 goes forwards
M569 P4 S1 ; Drive 4 goes forwards
; If you use an endstop switch for Z homing, change Z0 to Z1 in the following line, and see also M558 command later in this file
M574 X1 Y1 Z0 S1 ; set endstop configuration (X and Y and endstops only, at low end, active high)
M667 S1 ; set CoreXY mode
M350 X16 Y16 Z16 E16 I1 ; set 16x microstepping with interpolation
M92 X63.69 Y63.69 Z800 E706.7 ; Set axis steps/mm
M906 X600 Y600 Z1200 E600 ; Set motor currents (mA)
M201 X800 Y800 Z400 E1000 ; Accelerations (mm/s^2)
M203 X15000 Y15000 Z200 E3600 ; Maximum speeds (mm/min)
M566 X600 Y600 Z30 E20 ; Maximum jerk speeds mm/minute
M208 X350 Y330 Z200 ; set axis maxima (adjust to suit your machine)
M208 X0 Y0 Z-0.5 S1 ; set axis minima (adjust to make X=0 and Y=0 the edges of the bed)
; Z probe
M558 P1 X0 Y0 Z1 ; Analog Z probe, also used for homing the Z axis
G31 Z1 P942 ; Set the probe height and threshold (put your own values here)
; The following M557 commands are not needed if you are using a bed.g file to perform bed compensation
;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the Z probe
M557 P0 X60 Y0 ; Four...
M557 P1 X60 Y300 ; ...probe points...
M557 P2 X300 Y300 ; ...for bed...
M557 P3 X300 Y0 ; ...levelling
;M557 P4 X175 Y165 ; 5th probe point for levelling
; Tool definition
M563 P0 D0 H1 ; Define tool 0
G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
M92 E706.7 ; Set extruder steps per mm (single nozzle)
;*** If you have a dual-nozzle build, remove or comment out the previous line, and un-comment the following 3 lines
;M563 P1 D1 H2 ; Define tool 1
;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
;M92 E420:420 ; Set extruder steps/mm (dual nozzle)
; Thermistors and heaters
;*** If you have a Duet board with 4.7K thermistor series resistors, change R1000 to R4700 to the following M305 commands
; You can also use S and B parameters to define the parameters of the thermistors you are using
M305 P0 B3950 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
M305 P2 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
;*** If you are using axis compensation, put the figures in the following command
M556 S78 X0 Y0 Z0 ; Axis compensation here
T0 ; select first hot end
Any help would be appreciated. I have a make gear M2 that is marlin based so I know that and printers. Just don't know what is going on with this.
