movement smoothness with Duet October 02, 2016 02:28PM |
Re: movement smoothness with Duet October 02, 2016 05:46PM |
Re: movement smoothness with Duet October 03, 2016 04:01AM |
Re: movement smoothness with Duet October 03, 2016 06:28AM |
Re: movement smoothness with Duet October 03, 2016 10:51AM |
unromeo21
I am running on 1.15c, that's the thing... Is it only my controller behaving like this, or is it a general issue?
o_lampe
I like the silence and smoothness of my 0.9° steppers with 128 microsteps from my RADDS.
Re: movement smoothness with Duet October 03, 2016 03:02PM |
dc42
o_lampe
I wonder how that compares with my 0.9° steppers and 256 microsteps from my Duet WiFi?
Re: movement smoothness with Duet October 03, 2016 04:29PM |
Re: movement smoothness with Duet October 04, 2016 04:23AM |
roboprint
Returning to the first post subject: I wonder how smooth your Duet WiFi with your 0.9° steppers and 256 microsteps at reasonably high speeds
unromeo21
The resolution of the circle is high, I created the file for this purpose, to test the movement. Don't worry, I did not created it in Sketchup with 30 something faces. It was created in Autodesk Inventor. Here is the G-code file > [www.dropbox.com]
These jitters / missfires happen on random places on the circle, and only a couple of times per circle, around 10-15 times. I also made a video, I just have to upload it..
Re: movement smoothness with Duet October 04, 2016 04:33PM |
Re: movement smoothness with Duet October 06, 2016 05:26AM |
Re: movement smoothness with Duet October 06, 2016 12:02PM |
Re: movement smoothness with Duet October 10, 2016 10:59AM |
Re: movement smoothness with Duet October 10, 2016 01:55PM |
dc42
I tried your file on my Ormerod running firmware 1.15e on a Duet 0.8.5. It moves very smoothly even if I turn it up to double speed. On alternate circuits there is a Z movement or a slight hesitation, always at the same point in the circle. The hesitation is where it switches from the outer to the inner perimeter.
Re: movement smoothness with Duet October 12, 2016 04:00PM |
Re: movement smoothness with Duet October 16, 2016 05:17AM |
Re: movement smoothness with Duet October 16, 2016 06:27AM |
Re: movement smoothness with Duet October 16, 2016 12:54PM |
6:43:11 PMM115 FIRMWARE_NAME: RepRapFirmware for Duet FIRMWARE_VERSION: 1.15e ELECTRONICS: Duet 0.85 DATE: 2016-10-02
Re: movement smoothness with Duet October 16, 2016 06:09PM |
Re: movement smoothness with Duet October 26, 2016 04:31AM |
