M567 Color mixing [feature request] November 18, 2016 03:46AM |
Re: M567 Color mixing [feature request] November 18, 2016 10:22AM |
Re: M567 Color mixing [feature request] November 19, 2016 06:51AM |
Re: M567 Color mixing [feature request] November 19, 2016 07:52AM |
deckingman
I'd have that would difficult to implement in practice given that the sum of the mixing ratios have to add up to 1.00 (or 100%). Suppose you forgot to put the minus sign in front of the first value in your example? How would the firmware know which one was correct and if they both are correct, it would then have to reduce the third value to compensate. At the moment, there is no error checking so if you increase one extruder without decreasing another, you'll get over extrusion. You have to be very careful how you use M567 (trust me, I've been there).
Re: M567 Color mixing [feature request] November 21, 2016 05:48AM |
Re: M567 Color mixing [feature request] November 21, 2016 05:58AM |
Re: M567 Color mixing [feature request] November 21, 2016 10:59AM |
o_lampe
If using multiple extruders for color mixing will become more popular or even a common feature, I can imagine a DWC interface that has sliders for each extruder with a lock function. Now, when I lock one slider and move another, the remaining slider will automatically change it's value to match the "flowrate" I have set. ( usually 100%)
Another way of choosing the mixing ratio, would be an image were we select the right color and the ratios would be set.
Re: M567 Color mixing [feature request] November 21, 2016 04:08PM |
o_lampe
BTW: I've notices on my RADDS with RRF1.14 the extruders retract a lot, every time I manually send a M567 command during a print. They only retract, which causes print failure.
I checked my config file and the M207 line, where the hardware retraction is set, is outcommented. So I don't know where this retraction might come from...
Re: M567 Color mixing [feature request] November 22, 2016 03:02AM |
Re: M567 Color mixing [feature request] November 22, 2016 03:09AM |
Re: M567 Color mixing [feature request] November 22, 2016 04:20AM |
o_lampe
Yes I'm using absolute extruder coord's. Don't know how to tell Cura to use relative. Maybe it's time to take the next step and look for another slicer.
But actually it will make things unpredictable, changing too much at once.
After looking closer to the retraction, I found that the extruder with lowered mixing ratio retracts and the raised rate extruder unretracts. So there is some logic behind it, but I can't control it.
Re: M567 Color mixing [feature request] November 22, 2016 04:50AM |
Re: M567 Color mixing [feature request] November 22, 2016 11:11AM |
Re: M567 Color mixing [feature request] November 22, 2016 04:38PM |
o_lampe
OK, I managed to slice a 2 color part with slic3r and it seems to work retraction/mixing-wise.
But although I only have one heater element, the heating stops when the tool is changed. That was also the case with Cura and e3d chimera.
I haven't found a workaround that keeps me from manually editing every single gcode file
Any ideas or are there plugins available?
Re: M567 Color mixing [feature request] November 23, 2016 03:19AM |
M563 Px D0:1:2 H1 G10 Px S0 R0
T0; M109 S???; T1; M109 S??? ; T2; M109 S???; T0;
Re: M567 Color mixing [feature request] November 23, 2016 05:28AM |
Re: M567 Color mixing [feature request] November 23, 2016 01:49PM |
