Slow home all
Posted by Johnonz
Slow home all
December 02, 2016 09:13PM
Hi all i recently decided to upgrade my printer to a Duet 0.8.5 and i must say that with a 7'' panneldue its now an awesome machine.
Its all up and running but when i home all the speed is painfully slow and im not sure why. Im not using a "Z" probe just old school endstops i had to change the gcode file so that it would use endstops. im not sure what i did wrong when i home each axis individualy its fine but home all is brutally slow.
Any help with this would be greatly appreciated
Regards John.
Re: Slow home all
December 03, 2016 03:07AM
Homing uses the specific files for each axis and are combined when you do all check the Homex.g and compare it to the Homeall.g File think you will find the difference is in the F parameter.
I cant tell you what to alter as it appears yours is a cartesian Printer whereas mine is a delta that only uses the Homeall one so not had to even look into the individual ones at all
The files can be found in the /SYS directory on the SD Card.
You could also post your Homeall.g file here for people to check and give better advice?
HTH
Doug
