New Duet Web Control 1.14 and RepRapFirmware 1.17a-ch January 04, 2017 05:48PM |
Re: New Duet Web Control 1.14 and RepRapFirmware 1.17a-ch January 05, 2017 03:11AM |
Re: New Duet Web Control 1.14 and RepRapFirmware 1.17a-ch January 05, 2017 03:23AM |
Re: New Duet Web Control 1.14 and RepRapFirmware 1.17a-ch January 05, 2017 06:07AM |
Re: New Duet Web Control 1.14 and RepRapFirmware 1.17a-ch January 06, 2017 12:51PM |
Re: New Duet Web Control 1.14 and RepRapFirmware 1.17a-ch January 06, 2017 01:21PM |
Re: New Duet Web Control 1.14 and RepRapFirmware 1.17a-ch January 07, 2017 05:35AM |
Re: New Duet Web Control 1.14 and RepRapFirmware 1.17a-ch January 07, 2017 03:46PM |
Re: New Duet Web Control 1.14 and RepRapFirmware 1.17a-ch January 07, 2017 04:01PM |
Re: New Duet Web Control 1.14 and RepRapFirmware 1.17a-ch January 07, 2017 05:18PM |
stephenrc
There's a set of arrows at one corner of the grid, red, green, blue. They start at the origin point.
Re: New Duet Web Control 1.14 and RepRapFirmware 1.17a-ch January 07, 2017 06:45PM |
PDBeal
What is probably bad/miss leading about this grid is the large gap between those three arrows and the start of your grid. On my coreXY, the IR sensor is +33mm from my nozzle, which means my probe points are all between X33 and X200. This then leads to an almost useless grid as it can't compensate from X0-X33. This leads me to believe this grid setup needs to have a probe very very close to your nozzle as in less than 5mm away from it for it to accurately probe the entire bed. Alternatively, the machine would need travel paths that allow the probe to go from min to max size of the bed so 0-200mm in my case meaning my length of travel for the head would really need to be -33 to 200 instead of the 0 to 200.
TLDR: Probe distance from the nozzle will affect the usefulness of this feature making it impossible to cover and compensate for the entire bed
Re: New Duet Web Control 1.14 and RepRapFirmware 1.17a-ch January 07, 2017 09:15PM |
dc42
If you are using my mini IR sensor, it's designed to fit below the heatsink of an E3Dv6 hot end so that you can get it close to the nozzle. The one on my delta is 13 mm from the nozzle. It used to be less, but the new E3D heater block that accepts PT100 sensors is larger than the old one.
Re: New Duet Web Control 1.14 and RepRapFirmware 1.17a-ch January 08, 2017 03:51AM |
