Could do with some help in getting my Duet board working over USB [RESOLVED]
Posted by David J
February 01, 2017 03:35PM
I'll start by saying that the conventional way of using a Duet - using the web page - is fine for a lot of my work, especially when I'm printing a well-established design. However, when I'm deep into prototyping, the ability to load up a design and play easily and quickly with slicing parameters is a huge bonus (usually in Repetier-Host). It matches the workflow I like to use on my RAMPS-equipped Prusa, because of the ability to stop a print, make an adjustment, clear the bed and restart in just a couple of minutes, even though in all other respects my Duet-powered CoreXY is superior. I can live with the slowness of the USB link in these situations.
This is my setup:
G&C CoreXY printer
Duet 0.6 board running the latest firmware and web code (well, the firmware is at 1.15c, so very close to latest).
Linux Mint 18.1 on an 8-core AMD-powered PC.
It almost works over USB - I can command moves in all 3 directions, extrude, etc. but Repetier-Host doesn't display the bed and hot-end temps - it doesn't appear to be receiving the data for them. Obviously I am not happy to print when I don't know what the temps are, for all sorts of practical and safety reasons.
Looking at Repetier-Host's 'Printer Settings', I'm using port /dev/ttyACM0 with a baud rate of 115200 (250000 isn't available in Linux without patching the kernel). Transfer Protocol is set to Autodetect (other choices are ASCII and 'Repetier protocol'). 'Use Ping-Pong Communication' is unchecked.
Can anyone see anything wrong here? Or is there something else I should be looking at? The only point I'd add is that although I'm a keen Linux user, getting deep into the command line is a challenge for me - though I can cope up to a certain level!
Edited 1 time(s). Last edit at 02/02/2017 05:10AM by David J.
Re: Could do with some help in getting my Duet board working over USB
February 01, 2017 04:51PM
Repetier Host worked with the Duet last time I tested it. Have you selected a tool? With no tool selected, I think the M105 command reports the bed temperature only.
Edited 1 time(s). Last edit at 02/01/2017 04:52PM by dc42.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet.
February 01, 2017 05:11PM
Where should I set that in Repetier-Host if I'm only heating the bed and hotend, rather than running an object's gcode?
Edited 1 time(s). Last edit at 02/01/2017 05:13PM by David J.
February 02, 2017 04:48AM
I just tested with Repetier Host 1.6.1, and I am getting bed temperature reported updated even with no tool selected. You need to have a tool selected to get hot end temperature reports. I had to go Manual Control and turn off the Info and Errors buttons at the bottom to stop it echoing all the commands that PanelDue is sending.
Edited 2 time(s). Last edit at 02/02/2017 05:25AM by dc42.
February 02, 2017 05:08AM
I have to apologise - yesterday must have been an off-day for my printer. Then, it wouldn't show the temps - today it does.
It is a bit slower though... I will have to see if I can get the port speed up (but I don't like interfering with the kernel!).
Sorry if I've made you waste time looking at this...
Cheers,
David
February 02, 2017 05:28AM
The port speed setting is probably irrelevant, because the Duet uses a true USB connection (not USB-over-serial), so there is no baud rate involved. It's possible that Repetier host takes notice of the baud rate and sends data more slowly when you set a low baud rate, although I doubt it. The important thing is to have "ping pong" unchecked.
February 02, 2017 08:31AM
Thanks. I might try setting Repetier-Host to 230400, which is a 'normal' speed for Linux... just for the hell of it...
February 02, 2017 10:03AM
Well, I set it to 460800 (another standard baud rate for Linux) and it continues to work nicely, which reinforces what you said about it being a true USB setup. The only thing that still sounds a bit clunky is when it's printing the 3-row skirt around the part - I have no idea why, as when it gets to the part itself it prints smoothly. I'm not going to stress about it though...
February 02, 2017 11:33AM
David J
That probably means that the skirt has some rather abrupt angles in it instead of smooth curves. Reducing the jerk setting in the firmware will make it sound better; but if you set it too low then curves will print slowly.
February 02, 2017 01:32PM
dc42
In this instance, it was circular. The piece itself is one of my test files - a circle about 60mm diam with a few shapes cut out of it. The skirt was a few mm outside of this. I'm wondering if the precision of the skirt circle was low - the equivalent to the $fn value in OpenSCAD. I've attached the STL file, for info.
It's a minor nuisance rather than a real problem, as it doesn't affect the actual print.
open | download - adhesion test.stl (32.5 KB)
