Wiring a resistor in parallel
April 15, 2017 03:27AM
I am about to start using duet wifi. I have a BLTouch and I need to wire a 240 ohms resistor in parallel to its wires. What is the best method to do this? Can anyone with a similar setup post a picture of that portion? Shall I remove the connector at the end of bltouch and solder it there (as it will have to be removed anyway, as the pin connections will require individual wiring to specific pins)?
Edit: I only have220 Ohms or 270 Ohms resistors. Would they be OK?
Edited 1 time(s). Last edit at 04/15/2017 08:07AM by drmaestro.
