Support for mixing extruders
Posted by fma
fma
June 19, 2017 04:37AM
Hi!
Does the support for mixing extruder support active mixing?
Thanks,
Frédéric
Re: Support for mixing extruders
June 20, 2017 05:48AM
My understanding of active mixing is that it is the same as passive mixing but with a motor to stir the filament in the mixing chamber. As such, it should not need any special support in firmware. If the motor needs to be controlled, I suggest you connect it to a spare fan output, but make sure you add a flyback diode if you are using a Duet WiFi prior to PCB revision 1.02, or an older Duet.
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
