Fan control is not working as aspected September 30, 2017 07:53AM |
; Configuration file for Duet WiFi (firmware version 1.17) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool on Thu Sep 28 2017 15:41:15 GMT+0200 (Mitteleuropäische Sommerzeit) ; General preferences M111 S0 ; Debugging off G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M555 P2 ; Set firmware compatibility to look like Marlin M208 X-5 Y-5 Z0 S1 ; Set axis minima M208 X210 Y210 Z190 S0 ; Set axis maxima ; Endstops M574 X0 Z0 S0 ; Define active low and unused microswitches M574 Y1 S1 ; Define active high microswitches M558 P1 X1 Y0 Z1 H5 F120 T9000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds G31 P500 X0 Y0 Z0.6 ; Set Z probe trigger value, offset and trigger height M557 X40:175 Y40:185 S40 ; Define mesh grid ; Drives M569 P0 S0 ; Drive 0 goes backwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X100 Y100 Z4000 E420 ; Set steps per mm M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min) M203 X15000 Y15000 Z240 E1200 ; Set maximum speeds (mm/min) M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2) M906 X800 Y1000 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Heaters M143 S260 ; Set maximum heater temperature to 260C M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0 M305 P1 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 1 ; Tools M563 P0 D0 H1 F1; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Network M550 PMy RepRapPro Ormerod 2 ; Set machine name M552 S1 ; Enable network ; Access point is configured manually via M587 by the user M586 P0 S1 ; Enable HTTP M586 P1 S1 ; Enable FTP M586 P2 S1 ; Enable Telnet ; Fans M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Custom settings are not configured M572 D0 S0.12
Re: Fan control is not working as aspected September 30, 2017 08:34AM |
Re: Fan control is not working as aspected September 30, 2017 09:16AM |
Re: Fan control is not working as aspected September 30, 2017 09:34AM |
Re: Fan control is not working as aspected September 30, 2017 09:54AM |
Re: Fan control is not working as aspected June 23, 2018 08:20PM |
; Configuration file for Duet Ethernet (firmware version 1.20 or newer) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool on Sat Apr 21 2018 17:49:51 GMT+0200 (Mitteleuropäische Sommerzeit) ; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M665 R265.11 L410.79 B116 H492.17 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X-3.98 Y0 Z-3.8 ; Put your endstop adjustments here, or let auto calibration find them ; Network M550 PDelta RR Duet ; Set machine name M540 PBE:EFE:AD:FE:ED ; Set MAC address M552 P192.168.10.110 S1 ; Enable network and set IP address M553 P255.255.255.0 ; Set netmask M554 P192.168.10.1 ; Set gateway M586 P0 S1 ; Enable HTTP M586 P1 S1 ; Enable FTP M586 P2 S1 ; Enable Telnet ; Drives M569 P0 S0 ; Drive 0 goes backwards M569 P1 S0 ; Drive 1 goes backwards M569 P2 S0 ; Drive 2 goes backwards M569 P3 S1 ; Drive 3 goes forwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X200 Y200 Z200 E107 ; Set steps per mm M566 X1800 Y1800 Z1800 E1200 ; Set maximum instantaneous speed changes (mm/min) M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min) M201 X2000 Y2000 Z2000 E1000 ; Set accelerations (mm/s^2) M906 X1300 Y1300 Z1300 E1400 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z-0.5 S1 ; Set minimum Z ; Endstops M574 X2 Y2 Z2 S3 ; Set endstops controlled by motor load detection ; Z-Probe M307 H3 A-1 C-1 D-1 M558 P9 X0 Y0 Z1 H10 F500 T4000 A3 ; Set Z probe type and the dive height + speeds G31 P25 Z0.9 X32 Y-17 ; Set Z probe trigger value, offset (X32 Y-17) and trigger height (Z0.76) M557 R90 S40 ; Define mesh grid ; Heaters M305 P0 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S120 ; Set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 I0 F500 H-1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P2 S1 I0 F4.7 H-1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Motor stall detection ;M915 X Y Z S10 F1 R1 ; Automatic saving after power loss is not enabled ; Custom settings are not configured
Re: Fan control is not working as aspected July 08, 2018 05:26AM |
Re: Fan control is not working as aspected July 08, 2018 08:49AM |
Re: Fan control is not working as aspected July 08, 2018 09:13AM |
