Bed temperature is hopping
Posted by Treito
October 08, 2017 05:03AM
Hello,
if I try to heat my bed the temperature is irregular. Also if the temperature is reached it is changing by some degrees. Where I have to look for the fault? I use a silicone heater with builtin thermistor. Duet 0.6 from Replikeo.
Best regards,
Sven
Slicer: Simplify3D 4.0; sometimes CraftWare 1.14 or Cura 2.7
Delta with Duet-WiFi, FW: 1.20.1RC2; mini-sensor board by dc42 for auto-leveling
Ormerod common modifications: Mini-sensor board by dc42, aluminum X-arm, 0.4 mm nozzle E3D like, 2nd fan, Z stepper nut M5 x 15, Herringbone gears, Z-axis bearing at top, spring loaded extruder with pneumatic fitting, Y belt axis tensioner
Ormerod 2: FW: 1.19-dc42 on Duet-WiFi. own build, modifications: GT2-belts, silicone heat-bed, different motors and so on. Printed parts: bed support, (PSU holder) and Y-feet.
Ormerod 1: FW: 1.15c-dc42 on 1k Duet-Board. Modifications: Aluminium bed-support, (nearly) all parts reprinted in PLA/ ABS, and so on.
Re: Bed temperature is hopping
October 08, 2017 06:43AM
Like causes are a bad connection in the thermistor wiring, or a short between the ground side of the thermistor and another ground.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet [www.duet3d.com].
November 04, 2017 06:20AM
I exchanged the bed heater completely but the problem still persists. So it seems that there is a problem with the Duet? Is it possible that the two pins from the sockets of the heater and the Thermistor may be connected? Next time when I remove the bed I will test it.
