G31 probe offset confusion January 03, 2018 04:01AM |
Re: G31 probe offset confusion January 03, 2018 05:17AM |
o_lampe
The X&Y parameters seems to be "distance from nozzle to probe", but Z seems to be " distance from probe to nozzle".
In my case, the probe is 35mm to the right ( X35 ) and 10mm to the front ( Y-10 ). It is also 5.1mm below the nozzle, but here I have to use Z5.1 instead of Z-5.1?!
o_lampe
IDK if using G29 cares about the X/Y offset. It seems it does the same routine with or without the offset.
o_lampe
Should I use XY offset for a Delta at all? It seems, the effector is lower the more I move it towards the Y-tower. That seems to be related, since the probe is mounted between the Y-rods.
Re: G31 probe offset confusion January 03, 2018 11:56AM |
o_lampe
That's right. The G31 Z parameter is trigger height. The X and Y offset parameters were added later, and were defined as distance from the head reference point to the probe, just like tool offsets are.
