this is what happens when mechatronics goes bad November 26, 2018 05:42PM |
Re: this is what happens when mechatronics goes bad November 27, 2018 01:57PM |
Re: this is what happens when mechatronics goes bad November 27, 2018 04:04PM |
Re: this is what happens when mechatronics goes bad November 27, 2018 07:00PM |
Re: this is what happens when mechatronics goes bad November 28, 2018 12:02AM |
Re: this is what happens when mechatronics goes bad November 28, 2018 09:02PM |
Re: this is what happens when mechatronics goes bad November 29, 2018 04:36AM |
shadowphile
I have some small copper heat sinks just right for the driver chips and I figured I might as well put them to use since I will be improving the cooling.
Should I put them on top of the chip or underneath? I can think of arguments for either one. I like underneath because easier place to mount the fan and heatsinks.
Same question about fan placement.
Re: this is what happens when mechatronics goes bad November 29, 2018 01:36PM |
Re: this is what happens when mechatronics goes bad November 29, 2018 01:43PM |
Re: this is what happens when mechatronics goes bad November 29, 2018 02:54PM |
Re: this is what happens when mechatronics goes bad November 29, 2018 04:06PM |
Re: this is what happens when mechatronics goes bad November 29, 2018 05:03PM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: this is what happens when mechatronics goes bad November 29, 2018 08:07PM |
Re: this is what happens when mechatronics goes bad November 29, 2018 09:22PM |
Re: this is what happens when mechatronics goes bad November 29, 2018 09:27PM |
Re: this is what happens when mechatronics goes bad November 29, 2018 10:12PM |
Re: this is what happens when mechatronics goes bad November 30, 2018 02:12AM |
shadowphile
I'm not saying the duet instructions are wrong or that there aren't mitigating details, but at first appraisal, forced air straight onto a hot surface will remove heat faster.
(straight into the hot surface drills air through any insulating air layer, plus making the air turn 90 degrees creates a lot of turbulence).
Re: this is what happens when mechatronics goes bad November 30, 2018 02:19AM |
shadowphile
BTW, how do you do really long runs if you don't print while asleep? Stay up for 20 hours? I do have to work weekdays but I can get a 40+ hour run in during the weekend.
Re: this is what happens when mechatronics goes bad November 30, 2018 01:54PM |
Re: this is what happens when mechatronics goes bad December 04, 2018 03:38PM |
Re: this is what happens when mechatronics goes bad December 04, 2018 09:14PM |
