Connecting Optical end stops to Smoothieboard
June 07, 2016 01:55PM
I used an optical Z=0 switch in my printer. The part I used was pulled from an Epson inkjet printer, but most of these opto interruptors are about the same. The open collector of the phototransistor is used to pull the signal line low. Here's how I connected it to the Smoothieboard:
This particular opto interruptor does not have any indicator LED to show when the light beam has been interrupted. When zeroing the Z axis I monitor the endstop status using the LCD panel. If you don't have an LCD panel you can use the M119 command via a host computer.
Son of MegaMax 3D printer: [www.instructables.com]
Re: Connecting Optical end stops to Smoothieboard
June 12, 2016 12:52PM
Thanks a lot smiling smiley
One can find general information about endstops here : [smoothieware.org]
I need to draw a diagram about opto-endstops for the wiki in inkscape, have not had time yet.
