Azteeg X5 GT - digital current control not working with SD6128 drivers August 09, 2017 09:45PM |
Re: Azteeg X5 GT - digital current control not working with SD6128 drivers August 09, 2017 11:49PM |
Admin Registered: 13 years ago Posts: 7,003 |
the manual
Setting Current limit for stepper driver using smoothieware's config file.
Each driver current limit can be set using the line below. Locate each line on the config file and set individually. Setting is in Amperes, 1.0 Amp. Reboot board to apply settings. These will work for Panucatt Drivers with digipot control, SD6128, SD5984, SD8825, BSD109A and BSD2100
alpha_current 1.0 # X stepper current
beta_current 1.0 # Y stepper current
gamma_current 1.0 # Z stepper current
delta_current 1.0 # Extruder 1 stepper current
epsilon_current 1.0 # Extruder 2 stepper current
Re: Azteeg X5 GT - digital current control not working with SD6128 drivers August 10, 2017 04:51AM |
Re: Azteeg X5 GT - digital current control not working with SD6128 drivers August 10, 2017 07:05AM |
