G Code for showing current thermistor impedance values available? August 14, 2017 05:13PM |
Re: G Code for showing current thermistor impedance values available? August 14, 2017 05:46PM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: G Code for showing current thermistor impedance values available? August 15, 2017 03:02AM |
Re: G Code for showing current thermistor impedance values available? August 15, 2017 04:14AM |
// List of pins which to ignore when asked to change by gcode, 0 and 1 are RX and TX, do not mess with those!
#define _E0_PINS E0_STEP_PIN, E0_DIR_PIN, E0_ENABLE_PIN, HEATER_0_PIN, analogInputToDigitalPin(TEMP_0_PIN),
Re: G Code for showing current thermistor impedance values available? August 15, 2017 08:10AM |
Re: G Code for showing current thermistor impedance values available? August 15, 2017 01:15PM |
Re: G Code for showing current thermistor impedance values available? August 15, 2017 11:13PM |
Re: G Code for showing current thermistor impedance values available? August 16, 2017 07:53AM |
Re: G Code for showing current thermistor impedance values available? August 16, 2017 11:37AM |
Re: G Code for showing current thermistor impedance values available? August 17, 2017 03:13AM |
I know this all, why do the people always think I am stupid. Is it my bad English?Quote
the_digital_dentist
Get any 100k thermistor (100k Ohms at 25C) for which the manufacturer provides an R vs T table (just about all of them have such tables in the data sheets). You can use that table to generate Steinhart-Hart coefficients. That is likely to be far more accurate than trying to create your own table from an unknown thermistor.
Re: G Code for showing current thermistor impedance values available? August 17, 2017 09:36AM |
Re: G Code for showing current thermistor impedance values available? September 04, 2017 04:19PM |
