Help G32 auto bed leveling December 01, 2017 04:01PM |
gamma_min_endstop 1.28^ # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground #gamma_max_endstop 1.29^ # Pin to read max endstop, uncomment this and comment the above if using max endstops gamma_homing_direction home_to_min # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop gamma_min 3.5 # This gets loaded as the current position after homing when home_to_min is set gamma_max 200 # This gets loaded as the current position after homing when home_to_max is set
# Levelling strategy # Example for 3-point levelling strategy, see wiki documentation for other strategies leveling-strategy.three-point-leveling.enable true # a leveling strategy that probes three points to define a plane and keeps the Z parallel to that plane leveling-strategy.three-point-leveling.point1 10.0,10.0 # the first probe point (x,y) optional may be defined with M557 leveling-strategy.three-point-leveling.point2 10.0,330.0 # the second probe point (x,y) leveling-strategy.three-point-leveling.point3 265,170.0 # the third probe point (x,y) leveling-strategy.three-point-leveling.home_first false # home the XY axis before probing leveling-strategy.three-point-leveling.tolerance 0.03 # the probe tolerance in mm, anything less that this will be ignored, default is 0.03mm leveling-strategy.three-point-leveling.probe_offsets 0,-40,-3.5 # the probe offsets from nozzle, must be x,y,z, default is no offset leveling-strategy.three-point-leveling.save_plane true # set to true to allow the bed plane to be saved with M500 default is false
Re: Help G32 auto bed leveling December 01, 2017 04:18PM |
Re: Help G32 auto bed leveling December 02, 2017 04:57PM |
Re: Help G32 auto bed leveling December 03, 2017 02:00AM |
Re: Help G32 auto bed leveling December 03, 2017 05:24AM |
M280 S12.9 ; Extend Z-probe G28 X0 Y0 ; Home X and Y G00 X150 Y150 ; Move to middle of bed G30 Z3.5 ; Home and preset Z value G00 Z10 ; Move away from Z-trigger G32 ; Run auto bed leveling G00 Z10 ; Move away to retract Z-probe M280 S4.5 ; Retract Z-probe
Re: Help G32 auto bed leveling December 03, 2017 05:52AM |
Re: Help G32 auto bed leveling December 03, 2017 03:16PM |
