Project description and Scheduling
Posted by VDX
VDX
November 08, 2018 05:44PM
Here the first draft of the "Ideas-Collection" with some of the more interesting concepts roughly summarized:
Thoughts on the project "Floating islands in the garbage continents".
Status: - in all oceans of the world "garbage whirlpools" have formed, in which huge quantities of floating garbage accumulate due to the ocean currents.
The largest are located in the Pacific - here there are two "garbage vortices", one in the direction of Australia, one in the direction of South America.
The "size" of the largest would roughly correspond to the extent of Central Europe, i.e. over 1000 kilometres in diameter!
The current amount of waste in the oceans is estimated at about 150 million tons, but this could still be far understated ...
Collection of ideas from other projects:
- collecting floating garbage on the surface, creating it on land and separating it and recycling it (project "The Ocen Clean-up" does this as a test)
Criticism: only floating garbage on the surface, ways to and from the country take very long
- Stop waste discharge from rivers into the seas - is already being tackled by some countries, most still superior or do nothing at all
- Fishing boats should not dump the "garbage by-catch" in the nets back into the sea, but collect it separately and hand it in for a "deposit" in the harbours - some of them already go out only for the "garbage" ...
- Various project to clean up the sea coasts ...
- Dutch build floating platforms for houses and greenhouses instead of building higher dams to protect the coastal areas from rising sea levels -- works only in river mouths and in protected coastal areas, not on the open sea (storm and too high waves)
- Project "Seasteading" wants to build "floating cities" in harbours and "quiet" coastal areas - "ring walls" as protection against waves, only conditionally "seaworthy" -- initially only planned as "sea domiciles" for rich and super-rich ...
Difference of the project "Floating islands in the garbage continents"
- first of all, large ships (discarded container ships and freighters, which are currently available at the "scrap price" because commercial shipping has collapsed) are to be used as "bases" with plants and machinery for plastic recycling and "charring", as well as equipment and facilities for large-scale construction with sufficiently large crews for a long-term/"permanent" stay to the "garbage continents", and on site (without long arrival/departure times) begin to build large/thick floating structures.
- From these large/thick (several tens to a hundred meters in size, several tens of meters in thickness/height) elements, even larger "rafts" are then to be assembled, which, due to their size/mass and stability, can themselves withstand storms and waves up to a height of more than 30m, and which, in combination, are also to serve as "breakwaters" for structures built further inside.
- these "base" elements should not be built like ships with walls and cavities, but rather as massive bodies with many small cavities for buoyancy - it is ideal if they are so heavy and have so much buoyancy that they float e.g. at a size of 100x100 meters and 50 meters thickness half (or more) in the water and half (or less) above it - on top of this more "sensitive" structures such as houses can be built.
- as building material all possible stable solid bodies are suitable, which in turn do not give off any plastic when crushed over time (sun, waves, collisions, ...) - e.g. stones, sand, (sand). Stones, sand, (coral) lime, plant/tang fibre, glass fibre, metal wires and rods (for connection/tensioning), glass hollow spheres (for buoyancy), solid material extracted from the plastic waste and chemically converted (inert) such as coal ...
Plant resins - e.g. lignin, which is currently a waste product in paper manufacturing and could later also be obtained from trees/plants and tan/seagrass planted on/around the islands - are suitable as binders to combine this into a stable, concrete-like mass (see e.g. polymer concrete for highly stable industrial plants, which is made up of sand, gravel and cast resin/polymer).
- over time, marine biotopes (coral reefs, etc.) will also form around the islands, or should also be created themselves (e.g. as a raw material source for coral limestone or fish for food supply).
- Energy production on site by sun, wind, waves, current, temperature differences, evaporation, ...
- with sufficient energy more than enough drinking water can be obtained from the sea water - but also salt and from the salt practically all known materials/chemicals of the chemical elements dissolved in the sea water, which can be extracted and separated e.g. by chemical/galvanic processes ...
- on these first "rafts" even more stable material can be "built up" over time in order to extend them to "real" floating islands with enough mass/carrying capacity and size for a permanent planting with trees and plants (also for food supply).
Over time, this could also allow "floating continents" with a diverse structure with coast/inside areas and also large inland freshwater lakes or saltwater inland seas (down to the ocean open or filtered).
- for the garbage drifting in the sea, below the surface (or already sunk on the ground), methods for collecting have to be developed - in the beginning with ships/rafts as "supply bases" an armada of smaller (autonomous) boats, drones and submarines has to be built, from which even smaller submarine threats launch and expose "micro-drones" near underwater garbage whose only task is to "cling" to the garbage and inflate "swim bladders" with which the garbage drifts to the surface and can be conventionally collected there...
Political implications:
- Artificial islands" outside the 200-kilometer EEZ areas around the coastlines are located in a "lawless" space where only maritime and international law still applies - so completely independent rules and legal structures or even "nationalities" can emerge on them!
- This would also be an opportunity to offer alternative housing to the currently "sinking" micro-nations that inhabit small islands that will be flooded by rising sea levels within the next decades -- currently several of these micro-nations have already started negotiations with other countries to accommodate their populations there.
- because of this "lawless" environment one has to think about the protection of the islands against e.g. pirates or attacks of other nations - in the beginning this would be done with mercenaries/protection troops and contracts with countries on the nearer mainland or neighbouring "islands" - later this should be regulated by the own population in the form of volunteers or also "conscription" ...
Ideas for implementation and for the "start", step-by-step expansion:
- Make idea known, win supporters, donations and active members
- Assemble equipment - ships, life support/supply/energy, plastics processing/recycling/carbonisation, building materials and equipment, ...
- Start projects" with smaller ships near the coast over a few weeks/months as pre-exercise and "show-case" for the interested parties and media
- Long-term projects" with volunteers over several months/years with larger ships and construction teams/facilities directly in the "garbage maelstrom".
- Building ever larger "rafts" to demonstrate seaworthiness and long-term stability and to increase the processing capacity for the collected waste.
- Creation of the first "self-sufficient" raft/island structures with production of energy, food and building materials on site
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [reprap.org]
VDX
Re: Project description and Scheduling
November 17, 2018 04:16AM
... a few more thoughts on the faster establishment and expansion of the "mega-structures" and on sustainability:
- instead of a massive basic body made of already "converted" (or almost completely reduced to coal) collected garbage, only a massive "shell" with a few meters thickness and inside with many cavities and access ways should be built.
- These cavities are then only filled with the material collected from the sea (preferably already sorted) - this is actually an enormously valuable raw material when we have developed "large-volume molecular technologies" with which the plastic and the other components of the "garbage" can be broken down directly into the basic molecules and processed.
- In order to get to the cavities quickly and efficiently, sloping and spiral ramp tunnels with sufficient width/height for vehicles should run through the island base - so material can be moved from and to the respective destinations at any time.
This would allow large floating bodies to be built up relatively quickly, which would then be gradually built up to their full size/thickness with the material collected and only partially "converted" for the building substance.
I imagine that the "bodies" of the floating islands consist of a kind of "amber" with sand, coal and supporting fibres in thicknesses of a few to several tens of meters and many isolated (partly completely "sealed", partly accessible) hollow lumen inside - similar to our "small" 3D-printed parts with a "shell" and a hollow honeycomb filling.
On the one hand this is enormously stable, but decays over time, e.g. in collisions or crumbling due to aging by sun and waves, but only into the relatively harmless particles from which the "shell" was built ...
Viktor
VDX
November 17, 2018 08:00AM
... some more ideas, how the material can be built up to "floating islands":
Another consideration would be to build the whole thing not only in the form of "flat mega-rafts", but in a kind of "inverted layer cake" -- e.g. at first a practically massive floating platform ... then on top of it the next "floor" at the circumference larger than the level below ... u.s.w., u.s.f. ...
This could be used to build parts of any size/depth, which are still relatively flat above water (or conical hollows towards the inside or the bottom, e.g. as basins for a freshwater lake), but which gradually or simply become deeper and deeper under water as a shallow cone, until they may even touch down on the seabed or an elevation on the seabed.
The pressure with increasing depth (+1bar each per 10m depth!) would also compress the shell material with inner cavities (which additionally stabilizes and strengthens it), which has to be considered for the "wall thicknesses" ... or from a certain depth on massively fill the outer hollows to increase the strength/stability of the substructure ...
Viktor
VDX
June 05, 2019 07:09PM
... transscription from German forum:
... to activate the topic here again a little bit, and also to show that the ideas/concepts are not necessarily only meaningful "beyond the horizon" ...
With building materials made of plastic (and other) garbage, buildings or infrastructure can also be built here, on land/in the cities ... something like this is often done for sidewalk slabs or borders ... why not think and build "bigger"?
Another point - more and more reports focus on upcoming "drinking water shortages after drought summers" -- in some countries, like Spain, this is already so dramatic that people like the lunatics make (illegal) well drillings down to over 100m depth to get (if at all) to the groundwater eye popping smiley
I have always been bothered by the fact that I pay once for tap water ... and then again for the sewage sad smiley
There are already some ideas with rain water cisterns or artificial ponds for water-recycling ... but still much too little.
There were once a few projects for small "personal" evaporation water collectors, but not active anymore.
One concept that I personally like is a transparent cone with a curved edge/reservoir at the bottom, which is placed on the water surface by a puddle or pond and collects some 10 to 100ml of distilled/clean water over a few hours by condensation and dripping of the evaporating and rising water vapour in the lower reservoir of the cone -- this also works on brackish water, so that "dirty water" could be recycled locally and possibly reused immediately.
To make clean drinking water out of this kind of distilled water, just add some salt and stir!
In order to do this effectively and on a larger scale, this "cone" should be larger than the size of a soccer ball (as in the original project), rather the size of a garden house or even larger, and spiral "channels" running from top to bottom should discharge the condensing water directly into the collection tank.
In principle, you could put something like this into the cooling towers of power plants or industrial plants -- what rises into the sky is clean distilled water!!
Viktor
