Problema funzione HOME Z December 04, 2013 12:12PM |
Re: Problema funzione HOME Z December 04, 2013 12:22PM |
Re: Problema funzione HOME Z December 04, 2013 05:45PM |
Re: Problema funzione HOME Z December 04, 2013 05:51PM |
Re: Problema funzione HOME Z December 05, 2013 03:18AM |
//// MOVEMENT SETTINGS #define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E #define HOMING_FEEDRATE {50*60, 50*60, 2*60, 0} // set the homing speeds (mm/min) // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {78.7402,78.7402,4000,760*1.1*2} // default steps per unit for ultimaker //#define DEFAULT_AXIS_STEPS_PER_UNIT {78.7402*2,78.7402*2,200*8/3*2,760*1.1*2} // default steps per unit for ultimaker #define DEFAULT_MAX_FEEDRATE {500, 500, 5, 25} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for r retracts
Re: Problema funzione HOME Z December 05, 2013 06:10AM |
Re: Problema funzione HOME Z December 05, 2013 08:48AM |
Re: Problema funzione HOME Z December 05, 2013 08:53AM |
Re: Problema funzione HOME Z December 05, 2013 09:16AM |
Re: Problema funzione HOME Z December 05, 2013 09:18AM |
