Re: Merakit printer reprap/restrap delta jenis karya3D February 08, 2016 02:44PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 08, 2016 06:35PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 08, 2016 06:48PM |
rollingdice
Mantap gan, coba dipilihin benangnya dari apa. Lumayan bisa menghemat timing belt.
Setor kerjaan hari ini dulu:
[attachment 72124 P_20160209_015550-1600x1200.jpg]
Custom two in one blower, pake kipas sentrifugal bekas laptop uk. 5cm. Kalo tdk ada bisa pakai kipas 5cm biasa, buang bingkainya trus masukin. Besok mau tes efeknya ke ngeprint overhang + hollow pyramid.
Re: Merakit printer reprap/restrap delta jenis karya3D February 09, 2016 07:52AM |
ryannining
rollingdice
Mantap pak ide blowernya.
Untuk benangnya itu saya beli di toko asesori yg ada manik2 nya juga, katanya itu untuk bikin kalung, gelang. Saya pake benang pancing ribet ngikatnya, yg ini gampang, tapi tetep kaku ngga molor kaya benang pancing.
Re: Merakit printer reprap/restrap delta jenis karya3D February 09, 2016 07:54AM |
rollingdice
Belom sempet foto semua gan, soalnya lagi dibongkarin pasang flying extruder. Tapi ini ada foto endstop switch pesenan agan ryan.
[attachment 71453 endstop+effectorLarge.jpg]
Intinya si microswitch dimasukin ke female PCB header, ah female headernya disolder + ditempel superglue ke segitiga atas. Nanti kalo mentok atas carriagenya nutup saklar si microswitch.
Re: Merakit printer reprap/restrap delta jenis karya3D February 09, 2016 09:43AM |
Bener bro....Quote
abiemanyu
rollingdice
mikro swicth tiap sumbu dikasih ya bos?
Re: Merakit printer reprap/restrap delta jenis karya3D February 09, 2016 09:59AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 09, 2016 10:57AM |
Pake PLA 1.75mm, beli langsung ke si Bos Ryan aja.Quote
abiemanyu
beli filament dmn?
jenisny apaan utk racikannya bos Riyannining?
Re: Merakit printer reprap/restrap delta jenis karya3D February 09, 2016 11:54AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 09, 2016 04:29PM |
ryannining
Maaf, secara default karya3D ga pake endstop. Kalo pake endstop, ga bisa pake firmware karya3D harus meracik firmware default kaya bro rollingdice. Saya sendiri blom punya stok endstop, besok coba tak cari di toko elektronik, kurasa pasti ada.
Untuk motor driver disarankan memakai arus paling rendah, cara settingnya bisa google, atau kalo secara default, putar aja potensio di driver sebanyak 1/4 putaran kebalikan arah jarum jam. Hal ini untuk mengantisipasi power besar motor saat homing menarik belt di posisi mentok.
Untuk filamen iya tersedia juga di tokopedia kok.
Re: Merakit printer reprap/restrap delta jenis karya3D February 10, 2016 01:02AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 12, 2016 08:44AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 12, 2016 10:27AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 12, 2016 05:47PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 13, 2016 03:33AM |
ryannining
hasil print ga ada bedanya.
Bedanya sebelum ngeprint harus memastikan semua lengannya berada diatas. Kalo ga diposisi atas, maka harus manual di tarik keatas. Biasanya perlu dilakukan 1x saja setelah connect ke printer.
Atau dilakukan saat tiba2 listrik mati, dan posisi lengan masih ditengah (misal lagi ngeprint tergenti)
Kalo endstop ga perlu ngecek, endstopnya yg ngecek.
Re: Merakit printer reprap/restrap delta jenis karya3D February 13, 2016 09:04AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 13, 2016 09:40AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 13, 2016 09:58AM |
rollingdice
Sharing dikit pengalaman merakit racikan agan Ryan.
Paket datang awal Januari lalu. Ngerakitnya dilakukan secara bertahap karena nunggu alat-alat dan bahan tambahan dateng.
Yang saya beli antara lain:
- Palu plastik
- Jangka sorong 300mm
- Epoxy resin
- Bubble level
- Teflon tape / selotip paralon
Setelah ketok sana ketok sini, ada beberapa trik penting yang saya tangkap:
- Di langkah perakitan effector, jangan lupa potong bowden tube lalu masukkan di antara hotend dan pushfit. Sebenernya ada fotonya sih di atas, tapi berhubung ane nubi, jadi baru ketahuan pas ngeprint ada flex filamen di antara pushfit dan hotend karena gak pake bowden tube.
- Cara pasang balljoint ke carbon tube agak beda di versi saya. Masukin screw ke balljoint sampe mentok > balurin superglue ke bagian baut yang masuk ke carbon rod > masukin screw ke karbon rod > lepas balljoint > pasang teflon tape di ujung screw 8-12 putaran > pasang balljoint. Teflon tape di sini tujuannya agar balljoint bisa diatur sehingga panjang carbon rod bisa diseragamkan tanpa membuat si balljoint geser-geser saat printer operasional.
- Cek level platform bawah dan platform atas, apabila kemiringannya beda maka ketok si platform atas di sudut X, Y, atau Z sedemikian rupa sehingga kemiringannya sama.
- Saya pertama upload software pakai yang versi tanpa endstop. Tapi berhubung saya dikirimin microswitch 3 biji, dipake aja deh daripada nganggur. Alhasil bikin configuration.h sendiri di situsnya repetier, programnya juga donlod baru versi vanilla (tanpa modif no endstop). Lebih nyaman juga seandainya komputer ngehang / mati lampu bisa dihoming dari repetier tanpa angkat manual. Untuk pemasangan endstop sendiri perlu sedikit skill solder sama part-part elektronik.
- Selesai rakit, sayakonfirmasi steps/mm dari printer pake jangka sorong. Firmware dari agan Ryan sih udah disetting sebenernya, tapi nggak ada salahnya ngecek sekali lagi.
- Selain itu, perlu cek juga parameter lain kayak delta radius, endstop correction, dan tower angle correction karena yang namanya cacat manufaktur itu pasti ada. Saya pake ini nih. Pilih 6 factor dan 7 point, kalo mau lebih akurat mungkin bisa pake 10 point. Jangan lupa firmware typenya pilih Repetier. Kalo selesai tinggal dimasukin aja angkanya ke firmware EEPROM lewat Repetier Host.
- Test print pertama, coba ngeprint yang bulet-bulet. Perhatikan nozzlenya, kalo terlalu neken/terlalu ngambang, sesuaikan endstop correction di EEPROM.
- Jika layer pertama susah nempel, coba oleskan UHU glue stick di printbed.
Hasilnya lumayan bagus, walaupun ngeprint 20mm cube masih ada deviasi 0,4mm di sisi Y (entah itu yang nggak bener rodnya atau jangka sorongnya karena belinya bukan mitutoyo
Foto-foto menyusul, next up: flying extruder mod
Re: Merakit printer reprap/restrap delta jenis karya3D February 13, 2016 12:31PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 14, 2016 11:34AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 14, 2016 11:36PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 15, 2016 01:02AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 15, 2016 09:47AM |
ryannining
layer ke skip bisa karena:
1. motor ga kuat, karena gesekan bushing dg as, coba diminyaki, saya pake minyak mesin jahit buat bushing
2. Ada blob yg akhirnya bikin head nabrak -> biasanya over extrusion, atau retract bermasalah, coba print tanpa retract
3. seperti point nomor 1, tapi dg cara ubah arus ke motor, besarkan kalo perlu kasi kipas di daerah motor tsb.
Hasil dri karya3d enlarge
[attachment 72558 IMG_20160215_130223.jpg]
Re: Merakit printer reprap/restrap delta jenis karya3D February 15, 2016 10:07AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 15, 2016 10:30AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 15, 2016 11:46AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 15, 2016 12:33PM |
ryannining
Saya dulu pernah bocor gara2 drat kendor, tak kasi itu tetep bocor.
Ada juga hotbox yg samping dari nozzle dan troat ada sekrupnya, itu juga suka bocor.
Tapi tak sumpat pake grenjeng malah sip dibanding tape teflon (selotif putih yg buat pipa itu kan).
Mungkin kasusnya beda.
Re: Merakit printer reprap/restrap delta jenis karya3D February 15, 2016 01:40PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 15, 2016 11:56PM |
Nah itu... Kalo pake sedotan doang kan bahaya sedotannya bisa bengkok kalo ada gaya di effectornya (misalnya ngehantam blob atau dinaikin manual pake tangan).Quote
ryannining
jangankan sumpit, sedotan murni tanpa apa2 dalemnya juga pernah bro wkwkwkwk.
Nostalgia ke post lama...
http://forums.reprap.org/read.php?52,504282
Hahahahahhaha.....
Tapi dulu oke gak gan pake bambu?
Re: Merakit printer reprap/restrap delta jenis karya3D February 16, 2016 10:51AM |
