This is my new extruder design for the Heavy Mendel :
It's more compact than my previous extruder and mostly made with printed parts, the last one was made from milled parts.
The sub-d cover is also printed :
More details about the full-metal hot-end :
The heater is made from an M6 insert with the external thread removed :
reprap.org]
The tip is an acorn nut drilled with a 0,5mm drill-bit :
reprap.org]
and hammered to reduce the hole size : [PIC]
reprap.org]
To keep the entrance of the hot-end cold, an assembly of aluminum plates and brass nuts forms a heat sink :
reprap.org]
Stl files and sketchup assembly are available on the Heavy Mendel wiki page : [
reprap.org]
