Re: Considering a new extruder design February 17, 2011 02:23PM |
Re: Considering a new extruder design February 21, 2011 08:35AM |
Re: Considering a new extruder design April 03, 2011 08:08AM |
Re: Considering a new extruder design April 04, 2011 05:05AM |
Re: Considering a new extruder design May 03, 2011 10:11AM |
Re: Considering a new extruder design May 08, 2011 07:01PM |
Re: Considering a new extruder design May 16, 2011 09:25AM |
Re: Considering a new extruder design May 16, 2011 02:02PM |
if volumes of 1/4 million could be sold
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Considering a new extruder design May 16, 2011 04:19PM |
Re: Considering a new extruder design May 16, 2011 06:21PM |
Re: Considering a new extruder design May 16, 2011 06:48PM |
Re: Considering a new extruder design May 17, 2011 01:39AM |
The idea behind the Raprap is nice, but mass production works better in most products.
it will be controlled using the EMC2 etch servo system
Re: Considering a new extruder design May 17, 2011 06:11PM |
Re: Considering a new extruder design May 17, 2011 06:43PM |
Admin Registered: 19 years ago Posts: 1,791 |
Re: Considering a new extruder design May 18, 2011 01:38AM |
I find it hard to believe you can define the habits of all reprap users?
Do you really want to know how the extruder works?
I know that along with self-built extruders, we've got a few entrepreneurs who do up and sell ... ?90%? of the extruders?
Re: Considering a new extruder design May 18, 2011 03:43PM |
Re: Considering a new extruder design May 18, 2011 06:44PM |
Re: Considering a new extruder design May 18, 2011 10:24PM |
Re: Considering a new extruder design May 18, 2011 11:29PM |
Re: Considering a new extruder design May 19, 2011 03:28AM |
I just meant that 'RepRappers are used to adjust the design to their needs', and that modifying the atmega code to run the servo of the extruder would be possible.
Another experience of Gen7 is, offering drawings in advance is a good thing, because you get user opinions before plunking down money and the copycats wait until the wider reception is confirmed, anyways.| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Considering a new extruder design June 27, 2011 11:29AM |
Re: Considering a new extruder design June 27, 2011 04:52PM |
Re: Considering a new extruder design June 28, 2011 11:05AM |
Edited 1 time(s). Last edit at 06/28/2011 12:00PM by mung.
Re: Considering a new extruder design July 01, 2011 08:41PM |
Re: Considering a new extruder design July 04, 2011 02:53AM |
Re: Considering a new extruder design July 07, 2011 05:32AM |
Re: Considering a new extruder design July 08, 2011 05:12AM |
Thermoplastic,Specific Gravity,Tensile Yield Strength Mpa,Tensile Modulus Gpa,Coefficients of Linear Expansion (10-6 'C),Thermal Conductivity W/(m·K),Specific Heat (J/kg K),Maximum Temperature Limit(oC),Melting point ABS-AcrylonitrileButadieneStyrene,1.08,48.0,2.34,108, 7.7,1420,80,- PVC-Polyvinyl Chloride,1.4, 55.0, 2.83, 54,6.3,1040,65,- CPVC-Chlorinated Polyvinyl Chloride,1.54,55.0,2.89,63,5.7,840,100,- PE-Polyethylene,.95,22.0,0.83,162,18.2,2300,70,- PEX-Polyethylene Cross Linked,.94,19.3,.,162,18.2,2300,100,- PB-Polybutylene,.92,29.0,0.38,129.6,8.5,1880,100,- PVDF-Polyvinylidene Fluoride,1.76,48.0,1.52,126,8.5,1210,150,- PEEK-Polyetheretherketone,1.27,97.0,3.59,46.8,-,-,240,340, PP-Polypropylene,0.91- 0.93,30-55,-,130,1.4-2.8,1850,80,160 PA-polyamide,1.15,82,2.93,99,0.25,2200,98,260, PC-Polycarbonate,1.2,60,-,65,0.90,1450,135,
/// the script does not currently scan the entire document (so all future posts are used), but should be possible to search for every occurence of the preformatted text with id 'myD' then format it all into a table in a popup window
function cv(a){ return window.open('','1311161654195','width=700,height=500,toolbar=0,menubar=0,location=0,status=1,scrollbars=1,resizable=1,left=0,top=0');return false;}
var pp=document.getElementById('myD').innerHTML.split("\n");
var v = String.fromCharCode(60); var A = String.fromCharCode(62);
var tb= v + 'table name=pday' + A; var ntb= v + '/table' + A;
var td= v + 'td' + A; var ntd= v + '/td' + A;
var tr= v + 'tr' + A; var ntr= v + '/tr' + A;
function tg(a) { return v + a + A; }
var p=pp;
var kk= v + 'pre id=myD style="visibility:hidden; height:1px;"' + A + document.getElementById('myD').innerHTML + v + '/pre' + A + v + 'h1 ' + A + 'polymer data' + v + '/h1' + A + v + 'form id=F name=F' + A + tb ;
var yy= p.length;
var i=0;
while ( i != yy)
kk = kk + tr + td + v + 'input type=radio name=s value=' + i + A + ntd;
row= p[ i ].split(",");
if( row[0] )
for( o = 0 ; o!=row.length; o++)
kk= kk + td + row[ o ] + ntd + ' ';
kk= kk + ntr + ' \n';
i++;
kk = kk + ntb + v + 'br' + A;
// now we should create a form to take the nozzle size and extrusion speed, and polymer type
// calculate -------- extrusion volume = (nozzle diameter / 2) * (nozzle diameter / 2) * 3.141
// calculate -------- mass in grams per second = specific gravity * extrusion volume in cc
// calculate -------- energy required = heat increase * specific heat * mass
/// all the above is wrong as there are other factors involved but it is a rough approximation........
rr="\"function d(a){return document.getElementById(\'F\').elements[a].value;} f=d(\'erate\'); g=d(\'noz\'); function ll(){var i=0; while(i!=" + i + "-1){ if( document.F.s[ i ].checked == true){ var gj = document.getElementById('myD').innerHTML; var gk=gj.split('\\n'); alert( gk[i-0] );} i++; }}; ll(); ";
scrr= rr + "alert(\'this script currently give no results \\n \' + f + '\\n' + g ); \" ";
kk = kk + "Pleased input the hotend parameters " + "nozzle diameter : " + v + "input type='text' name='noz' /" + A + "extrusion speed: " + v + "input type='text' name='erate' /" + A ;
kk = kk + v + "input type='button' value='Calculate' onclick=" + scrr + A + v + "/form" + A;
f= cv(''); //window.open();
f.document.write(kk);
//cv(kk);
Re: Considering a new extruder design July 10, 2011 01:20PM |
Re: Considering a new extruder design July 10, 2011 01:50PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Considering a new extruder design July 11, 2011 04:13AM |
