I need to match
this greg's extruder with
this arcol hotend. In the beginning i used steel wire to connect the two, but that has begun to move when i extrude leading to a plastic mess.
What i would like to do is replace the top wooden disk with an aluminium adaptor plate that is then bolted to the extruder to prevent movement.
I already have a bit of plate which should be sufficient for the job but not enough for a second try. So I want to create a paper template, similar to what Nophead mentions for the Mendel90. Ideally is just import the 2 files and take a slice and go from there. If this is not possible, i'll just go dig through openscad files (man i really wish technical drawings where available.. oh well)...
In any case what tools and formats would you recommend to create a paper template, and how do you make sure that you print to the right scale?
Are there free/cheap tools available to create technical drawings, (ideally from the 3d model)?
The freecad installation does not work on my computer so i'm stuck there.
evert
