Hi all,
I seem not to be able to modify other people's .STL files in OpenScad
When I import ( or stl-import, no differences) an STL file and I add some structures in which I diffence some text, the compile [F5] will show as expected, however,
The rendering [F6] will remove the imported object, leaving only my added code.
And as expected afterwards, the new exported STL also lacks the imported object :-(
As said, no matter which import statement I use.
Any clue's
Advice appreciated
Thomas
Edited 1 time(s). Last edit at 01/19/2013 08:57AM by Replace.
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
