How to resize an .stl
September 16, 2014 10:48AM
I want to print an auger, but am to noob to make my own, but downloaded one on thingiverse, but its hudge. Its like post hole digger size. I want to resize it down to
inch size. Is this possible and how? I have Art of Illusion and FreeCad, but can't figure a way. Anyone can help?
Thanks,
Dave
Re: How to resize an .stl
September 16, 2014 10:58AM
FreeCad should work fine as should Art of Illusion.
I would recomend using netfabb Basic, "Part - Scale - Enter value - Scale".
Then "Part - Export part - as STL...".
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
September 16, 2014 11:09AM
Wow, thanks much for the awesome quick reply! I will try netfabb Basic.
Dave
September 16, 2014 11:35AM
I tried netfabb Basic and it seams like a pretty cool utillity, but when I scale the stl and save it. Then open it in anything else no object appears on
the screen. I will fiddle with it more, the same happens when I resize it with FreeCad. I also noticed that netfabb reports the size as being different than FreeCad.
But I thank you very much, for giving me something to start with. Perhaps my resize attempt is to great and should just try to find a smaller auger. It just sucks that on thingiverse they dont give you size of object. You have to download it then load it in something to find out how big it is.
Dave
September 22, 2014 10:10AM
You can use Slic3r to scale the object in all 3 dimensions by a percentage,
it tells you how large the object is going to be, and it allows export to STL.
This method is limited to X+Y+Z scaling, you can't use it to stretch objects!
If you know OpenSCAD you can import and scale each axis separately.
RS-Online Ormerod #263, Kossel mini with Minitronics, Prusa i3 MK2
September 22, 2014 11:36AM
I usually do my scaling with meshlab.
September 23, 2014 02:18PM
You can scale an .stl from within KISSlicer and Slic3r. Maybe Skeinforge too; I didn't look and don't remember from memory.
October 01, 2014 03:07AM
Repetier host also has this ability built in pre slicer and it can be axis independent or locked.
HTH
Doug
October 29, 2014 02:55AM
And of course: you can import and scale in OpenScad.
And export as .STL again
Thomas
Edited 1 time(s). Last edit at 10/29/2014 02:56AM by Replace.
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
