"Engraving" JPG into STL April 07, 2016 03:33PM |
Re: "Engraving" JPG into STL April 07, 2016 04:49PM |
Re: "Engraving" JPG into STL April 07, 2016 08:06PM |
Re: "Engraving" JPG into STL April 07, 2016 08:46PM |
Re: "Engraving" JPG into STL April 07, 2016 10:39PM |
frankvdh
There's not a lot you can do with an STL file, unfortunately.
FreeCAD does allow you to import an STL, convert it to a "shape", then to a "solid". Then you can do boolean operations to (e.g.) cut a recess or whatever. Beware that things get *very* slow when you do this.
I expect (although I haven't actually tried) that FreeCAD has some way to import images. Probably vector images could even be automatically converted to a sketch, ready for extrusion.
Re: "Engraving" JPG into STL April 08, 2016 08:45AM |
Re: "Engraving" JPG into STL April 11, 2016 02:16AM |
rhmorrison
I use OpenSCAD for this all the time!
You can use shapeways to Turn your 2D design into a 3D print, or InkScape to trace the part and export as .dxf that can then be used by OpenSCAD. See "How to Trace an Image Using Inkscape" for how to do this.
For example, see my business card holder on Thingiverse.
Re: "Engraving" JPG into STL April 11, 2016 02:48AM |
difference() { object1; \\ THE OBJECT object2; \\ The object you want to SUBTRACT }Note: When trying to position use union() instead of difference() then when it looks right use intersection() instead of difference() to see exactly what the intersection is and when correct THEN use difference() to generate the object to print.
Re: "Engraving" JPG into STL June 23, 2016 03:27PM |
Re: "Engraving" JPG into STL August 19, 2016 03:13PM |
Re: "Engraving" JPG into STL August 19, 2016 10:40PM |
Re: "Engraving" JPG into STL February 12, 2017 11:14AM |
Re: "Engraving" JPG into STL October 07, 2017 09:43AM |
Re: "Engraving" JPG into STL October 07, 2017 12:52PM |
Admin Registered: 16 years ago Posts: 13,902 |
