X,Y and Z "endstop" triggering by pushing wire to activate a single lever-based probe (renishaw or otherwise) May 09, 2016 09:56AM |
Anonymous User
Re: X,Y and Z "endstop" triggering by pushing wire to activate a single lever-based probe (renishaw or otherwise) May 10, 2016 01:50AM |
Re: X,Y and Z "endstop" triggering by pushing wire to activate a single lever-based probe (renishaw or otherwise) May 10, 2016 02:43AM |
MKSA
I have seen similar set up but Instead of the renishaw it was a claymore mine
Anonymous User
Re: X,Y and Z "endstop" triggering by pushing wire to activate a single lever-based probe (renishaw or otherwise) May 10, 2016 05:50AM |
Re: X,Y and Z "endstop" triggering by pushing wire to activate a single lever-based probe (renishaw or otherwise) May 10, 2016 06:01AM |
Anonymous User
Re: X,Y and Z "endstop" triggering by pushing wire to activate a single lever-based probe (renishaw or otherwise) May 10, 2016 09:52AM |
realthor
Use a single "sensor/probe" and a wire loop system to be used as a medium to trigger the sensor/probe, with no moving components.
Re: X,Y and Z "endstop" triggering by pushing wire to activate a single lever-based probe (renishaw or otherwise) May 10, 2016 04:53PM |
MKSA
realthor
So what are the advantage compared to 2, eventually 4 microswitches ???? (a renishaw is just that, 3 switches, well made and very expensive).
Note that for my Z axis, I indeed modified the microswitch which I do not consider fit for this positioning job (OK for X and Y), to work like the simple circuit opening of the renishaw (berylium leaf spring and gold plated contact) !
