Spares or Repair
July 30, 2016 07:18AM
Im putting my beloved 1st reprap up for sale it comes with 4 motors heatbed ramps and arduino ill chock in my old extruder with a pgl35 motor on it has for stepper drivers the z driver has two motors on it. no psu ill chuck in the jhead hotend its had alot of use out of it, i want quick sale so im looking for £50 plus £10 cover shipping due to weight grab a bargain the motors are 740z-inch heat bed is 12v you cant really buy new a good set of steppers for £40 so i think its very cheap to buy this for parts or spares or get it going it wont take much plus it has a lcd panel too
check my undated blog in signature
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
Re: Spares or Repair
August 01, 2016 12:55AM
really need it gone
up and running
August 02, 2016 03:33PM
also can split if needs be the spec of the motors are 4 of
Part No.: 42BYGHW811
Frame Size: NEMA17
Step Angle: 1.8 degree
Voltage: 3.1V
Current: 2.5 A/phase
Resistance: 1.25Ohm/phase
Inductance: 1.8mH/phase
Holding torque: 70oz-in
Rotor inertia: 68g-cm2
Detent torque: 280g-cm
Number of wire leads: 4
Weight: 0.34 kg
Length: 48mm
they have wire extensions and connectors and heat shrink tube arround soldered joints none of the original wires to motors are cut
arduino mega but its a clone but works ok never had issue
4 drivers with ramps
a heatbed (12v)
lcd panel
frame
anything can be seperated
up and running
March 23, 2017 10:16AM
bump
up and running
