Cheapest method to get 100kg ABS inside EU
November 30, 2009 04:06PM
Hi!
Im planning to invest into some plastic. So I want to buy 100kg of 3mm ABS, do somebody know some really cheap options?
I have read in this forum some time back, that someone from italy wanted to buy 100kg of ABS, but I cant find the post anymore.
I know one option:
100*40GBP from bitsfrom bytes (4000 GBP), its out of my pocket:-(
Best regards,
Khiraly
Re: Cheapest method to get 100kg ABS inside EU
November 30, 2009 04:57PM
You can buy it at Makerbot for 1340 GBP, which is just a third.
Flight would add another 300 GBP or so, and you'll probably have
to pay some extra charge for overweight luggage and customs, but
you'll still come out ahead.
Alternative is to have Makerbot ship it via UPS (split in two packages)
or DHL for about 800-1200 GBP. Even though cost almost doubles, it would still be far cheaper to get it from the US compared to BfB.
Just curious: why would you need THAT much plastic? This would be
months (or years?) of continuous printing...
-Geert
November 30, 2009 05:04PM
There was a chinese option, which was about 200$ for 100kg + shipping (700$?)
December 12, 2009 07:55PM
From RepRapSource you can get 20 x 5 Kg x 98.50 €/Kg = 1,978 €
January 06, 2010 09:44AM
Hai
Anyone wanting ABS 3mm extruded supplies we can provide the support by direct air shipment to your destination.
What we want is a minimum of 100 kgs shipped. we can provide the same in continuous coil form of 5 kgs or 10 kgs as the need may be.
We have around 8 extrusion machines that can custom manufacture any color and grade and we also offer Homo and co PP , PVC, Polyacetal and TPU materials in 3 mm size.
As airport rates differ for freight destinations. Please post your message for all your needs.
JAGS
DESIGN FOR A CHANGE!
Hi JAGS,
How much would 100 kgs of ABS cost, including shipping to the UK?
KFB
Just make sure that the tolerances are at max 3.0mm +0.05mm -0.1mm before ordering big. I had oval filament, and believe me its not worth the trouble. The extruder gets unreliable and unprecise. [blog.arcol.hu] had the same issues.
April 20, 2010 08:28AM
I have never managed to buy such close tolerance filament. Most "3mm" filament from the US seems to be 2.85mm for some reason.
Oval is a pain though because you need a larger than optimal extruder bore and it gives slightly inconsistent feed rates with a threaded pulley pinch wheel. Not a big effect but I got a noticeably increase in quality when switching to round.
KFB
April 21, 2010 02:30AM
Thanks for the advices, will certainly sample before buying.
