Builders
Revision as of 13:47, 18 January 2010 by TheOtherRob (talk | contribs) (Redirecting to Category:Development)
Redirect page
Notice
This page has been superseded by a category-based development page for better scalability to contain all RepRap-based development and extension. All links have been migrated to the new development pages or their appropriate help section. Please see Category:Development.
This decision was made by user:theOtherRob in the spirit of do-ocrasy, if you disagree please leave me a comment and we can collaborate on a better solution.
--TheOtherRob 17:47, 18 January 2010 (UTC)
RepRap Detail
This is the place for you to write up improvements to RepRap and RepStrap machines. It is also the place to post ideas that you think will help other RepRap users, particularly new ones.
Please include as many pictures and diagrams as you can; these really help understanding.
Don't be frightened to tidy, to re-organize, to correct and to clarify the work of others, but don't delete anything without good reason (good reasons are things like the post is offensive, is spam, or is scientifically incorrect).
Edit Policy: Am I allowed to edit this random page or create a new page?
Yes. If there's an edit button-link, you can edit. If it says "There are security restrictions on this article" on a page called Foo, create Foo/Patch and go crazy. Cut and paste the source from Generic if you want.
This was already blogged, should I paste it into the wiki?
Generally, if it was good enough to blog, it is good enough to go in the wiki. So by all means include lasting information that has previously appeared in the Main Blog, the Builder's Blog or the Forums - we want to systematize that in a chronologically-independent way here. But please don't post questions (they belong on the Forums) or information that is transient.
There is a dedicated forum thread here for discussion of this Builder's wiki, what should go on it, and how it should be organized.
Should I edit Builders and add a link to my new page?
Yes. Probably. Unless it doesn't make sense to you to do so. But in that case add a link add a link to your new page somewhere so it doesn't end up on Special:Lonelypages
New and Experimental Documentation
User-submitted Hints, Files and Patches to RepRap Version I Darwin
Click on one of the links below to take you to the appropriate section of the Builder's Wiki for you to post your work.
Thermoplast Extruder Version 2
extruder
User-submitted hints, variations, patches, and improvements on the Thermoplast Extruder Version 2
Please try to stick to the headings below, each of which links to the page to use to post your work.
Cartesian Bot
bot
User-submitted hints, variations, patches, and improvements on the [Cartesian Bot].
Electronics
motor controller
User-submitted hints,variations, patches, and improvements on the [Electronics] to control a RepRap.
Software and firmware
Java development
User-submitted hints,variations, patches, and improvements on the [Software] to control a RepRap. There are separate sections for the firmware in the machine, and the software that drives it from the host computer.
  • Builders/Host software If you want to add to the information on the RepRap host software, follow the link above.
  • Builders/Firmware If you want to add to the information on the RepRap microcontroller firmware, follow that link.
  • Builders/Software alternatives If you have an alternative RepRap driving program or alternative firmware (for any microcontroller) this is the place to document it.
  • Useful Software Packages This is the palace to put details of software packages that are useful for RepRap (like CAD programs), but that are not part of the RepRap project itself.
Configuration
User-submitted configuration hints, examples and suggested settings. Scared of the hundreds of numbers? Start here.
Links and Blogs Of Reprap Builders
  • Builders/Links_and_Blogs A collection of links to different blogs and websites which deal directly with RepRap, or are of Interest to RepRappers.
User-submitted Hints, Files and Patches to RepStrap machines
A RepStrap is a homebuilt 3-axis positioning system used as a 'bootstrap' machine to fabricate a RepRap 3D Printer.
LaserCut Repstraps
Builders/LaserCut RepStraps
  • There are a growing number of laser-cut Rep(St)raps being developed. Follow that link to find out about them, to add details of yours, and to see why the (St) is in brackets...
Repstraps
Builders/RepStraps
  • If you've built a non-laser-cut RepStrap, this is the place to tell people about it.
Soft Tooling for Casting
| The Soft Tooling for Casting page is not really a RepRap technology. But it is a very useful and easy way to make complicated parts. Follow the link for instructions.
RepRap documentation in different languages
RepRap in Different languages
RepRap collaborative publications
Collaborative Publications
Archive and obsolete
Thermoplast Extruder Version 1
extruder
User-submitted hints, variations, patches, and improvements on the Thermoplast Extruder Version 1
Please try to stick to the headings below, each of which links to the page to use to post your work. Note that this extruder is being superseded by the one above.
Tutorials
Soldering Tutorial
[Soldering Tutorial]
