FoldaRap Build Manual
Revision as of 04:56, 8 February 2013 by Bools (talk | contribs) (Wiring: add the wiring diagram)
FoldaRap Documentation
Tools required
  • 1,5 mm Allen wrench (for the pulleys grub screw)
  • 2 mm Allen wrench (for M3 counterksunk bolts and pneumatic fittings "MA-12-03-M5")
  • 2,5 mm Allen wrench (for normal M3 cap-head bolts and the rounded M4 bolts used for the frame)
  • little flat screwdriver (1,5mm) (for the board's screw terminals)
  • Philips (PH2) or flat screwdriver (3mm) (for the psu's screw terminals)
You may need also :
  • a small pliers and a large one (to tighten the hotend)
  • something to cut wires, and something to strip them (knife, automatic striper, etc.)
  • iron (for wires, ferules and board terminals)
  • a lighter for the heat-shrink sleeves
  • small files (round, flat) to eventually ream the printed parts
  • a glue gun (gluing the endstop on the printed part is easier/quicker than using bolts)
Overview In case of doubt, don't hesitate to have a look at the 3d model in Sketchup (before/during the build) ! It will show you the folded/unfolded state of the machine and you can play around with it :)
Basically we have a main frame and several sub-assemblies, some can be done in parallel : gather your friends and establish a record of minimum building time !
I tried to make a Gantt diagram for that :
General tips :
  • Work on a cutting mat if you have one, it will protect your table plus they often show a millimetre grid that will be useful to check the bolts length (but with some experience you will recognize them just by looking or holding one).
  • Place you mouse over a picture in a list if you wonder what part it is
  • How to insert a T-nut : T-nut insertion.jpg Tightening torque : 2.5 Nm (+/- 5%)
<videoflash>9CAiVmfO2mk|320|240</videoflash>
Ok let's start
It should take between 4 and 20 hours to put everything together, depending of your experience and some sub-assembly that may have been already prepared.
Know the parts
Firstly, have a look at all the part and learn what everything is.
Z-axis
Caution : on the aluminium extrusion some corners are better than others, take care to choose one that slide well for the X-motor and X-idler, keep it in mind then when assembling the Z-right and Z-left.
hinge detail
movement
Right
Foldarap hinge-outer-right.jpg x1 Foldarap hinge-inner-right.jpg x1 Foldarap z-motor-bracket-right.jpg x1
20x20 300mm.jpg x1 M4x8 round-head.jpg x2 T-nut.jpg x2
Nema14.jpg x1 (17cm wires for the z-right) M3x8.jpg x3 M3x20.jpg x1 M3 nut.jpg x1
  • vinyl coupling (pushed half-lenght on the motor shaft)
<videoflash>xxfFqePB1qk|320|240</videoflash>
Left
the lever is oriented toward the left (exterior)
people usually twist the wires of the endstop and motors, to reduce interferences and make them more tidy
Foldarap hinge-outer-left.jpg x1 Foldarap hinge-inner-left.jpg x1 Foldarap z-motor-bracket-left.jpg x1
Nema14.jpg x1 (25cm wires for the z-left) M3x8.jpg x3 M3x20.jpg x1 M3 nut.jpg x1
Micro-switch with-lever.jpg x1 (with 25cm blue wires for z-endstop, fix with an m3x8 or simply use a glue gun)
<videoflash>E0LTPixdv0M|320|240</videoflash>
Rear Base
exploded view
assembled
Foldarap foot-rear-left.jpg x1 Foldarap foot-rear-right.jpg x1 20x20 200mm.jpg x2 20x20 300mm.jpg x4
M4x8 round-head.jpg x8 T-nut.jpg x8
<videoflash>R-FKKoWC1hw|320|240</videoflash>
Front Base
exploded view
assembled
Foldarap foot-front-left.jpg x1 Foldarap foot-front-right.jpg x1 20x20 200mm.jpg x2
M4x8 round-head.jpg x8 T-nut.jpg x8 Micro-switch with-lever.jpg x1 (with 32cm green wires for y-endstop, fix with an m3x12 and m3 nut or glue gun)
<videoflash>zFjVM068mtI|320|240</videoflash>
y-idler
FoldaRap y-idler 603zz.jpg M4x8 round-head.jpg x2 T-nut.jpg x2
M3x20.jpg x1 M3 washer.jpg x2 623zz.jpg x2 (603zz)
<videoflash>VHMia_wi4TQ|320|240</videoflash>
Bed-plate
Foldarap bed-insulation-leveling-plate.jpg x1 Foldaslot peltier12708.jpg x1 M3x12 countersunk-head.jpg x4 M3 nut.jpgx4
(m3x10 is fine, but the m3x12 allow you to eventually add a sheet of insulation above the wood plate)
  • alu plate
  • thermistor (26awg blue 30-35cm, ferules, kapton)
  • kapton
<videoflash>cq9UrSuX4wo|320|240</videoflash>
Tip : use the wood plate to center the position of the peltier
Y-carriage
lasercut version
Foldarap y-carriage and belt-clamp.jpg x1 or Foldarap y-carriage lasercut.jpg + Foldarap belt-clamp.jpg
  • 600mm belt (pay attention to its length, it's the shortest of the two, as the one for the X axis is 700mm)
M3x12.jpg x2 M3x30.jpg x3 M3 nut nylock.jpgx3 M3 nut.jpgx8 M3 washer.jpg x6
RJMP-01-06.jpg x3 (or LM6UU)
  • bed springs x3
  • zip-tie x3
+Bed
Tips : if the bearing mount are too loose, you can add a little drop of glue or a very small amount of blue tack in the bearing grooves.
<videoflash>m6JDE4KDay4|320|240</videoflash>
  • Clamp the belt in the middle of it's length
X-motor
Foldarap X-end motor.jpg x1 M3x16.jpg x3 M3 washer.jpg x3 Nema14.jpg x1 (50cm wires) Pulley-T2.5 paopart.jpg x1
Micro-switch with-lever.jpg x1 (with 50cm red wires for x-endstop, fix with an m3x8 or glue gun)
<videoflash>ffVmqxLEW58|320|240</videoflash>
Extruder
Don't forget to make a flat on the shaft if there isn't one, using a file
with a rubber roller
with a bearing and a bolt
M3x12.jpg x2 M3 nut.jpg x3 M5 nut.jpg x1 Pneumatic-fitting MA1203M5.jpg x1
M3x35.jpg x1 M3 washer.jpg x3 200px x1
623zz.jpg x1 M3x20.jpg x1 (some early versions are using a rubber roller instead)
If your motor came with an aluminium gear, here is how I remove them (M4 bolt+hammer+vice) :
<videoflash>pT2zk--KqBo|320|240</videoflash>
<videoflash>Qw6U9_q8BCo|320|240</videoflash>
Hotend and thermistor
  • resistor 60cm 22awg wire
  • thermistor 60cm 26awg (or leftover from the motors)
  • fan prolongated to match 60cm
<videoflash>tW_CswHS2OM|320|240</videoflash>
This video is the first I made of these series, and is far from perfect (bowden tube goes before the heatsink!). I'll remake it later but for the moment it's better than nothing (and there is always a good doc on the RepRapPro_Huxley_hot_end_assembly)
Power Supply
Foldarap underplate.jpg x1 M4x8 round-head.jpg x6 T-nut.jpg x6
200px x1 M3x8.jpg x4 M3 washer.jpg x4
<videoflash>_tXWGjJq0zM|320|240</videoflash>
  • Bolt the PSU on the plate, with a washer between the psu and the plate
120W PSU
Which have a slightly different mounting.
Board
Foldarap board-mount.jpg x1 M4x8 round-head.jpg x3 T-nut.jpg x1
  • board
  • stepper drivers
It is maybe a good time to check if the stepper drivers are correctly set (see Pololu_stepper_driver_board and SureStep82 user guide) (Vref = 0.4 for the nema14, 0.32 for the PG35L)
You don't need to plug the power supply for that, if you have set the jumper to "usb" instead of "int", the USB connection is enough for this checking phase.
  • board to power supply : 8cm red/black wires
<videoflash>o5W4oZXCXOw|320|240</videoflash>
Y-motor
don't forget to insulate the ferules
Foldarap y-motor.jpg x1 M4x8 round-head.jpg x3 T-nut.jpg x3
Nema14.jpg x1 (15cm wires) Pulley-T2.5 paopart.jpg x1
C14 CEI male-plug.jpg x1 6,35mm-faston-ferule.jpg x7 M3x8.jpg x5 M3 nut.jpg x2
  • big blue switch
  • heatshrink sleeve
  • Power supply to male plug : 1 green wire 18WG of 15cm (35cm for the TXH240), one end with ferule, the other end just stripped
  • Switch to power supply : 1 red and 1 black wire 18AWG of 15cm (35cm for the TXH240), one end with ferule, the other end just stripped
  • Switch to male plug : 1 red wire of 6cm, 1 black of 9cm 18AWG, both ends with ferule
<videoflash>BiiBkZKw1og|320|240</videoflash>
Great ! You are almost done !
Have a pause, you need to be relaxed for the next step, or you can also just head to the end :)
Wiring
At this stage you should have all of these sub-assembly :
Now lets plug everything to the board !
  • 18 AWG : power
  • 22 AWG : heat
  • 26 AWG : sensors (you may use the leftover from the motors)
  1. Y-motor (15cm, under the board)
  2. X-motor (50cm)
  3. Z-motors (17cm and 25cm)
  4. Extruder-motor + fan
  5. Y-endstop (green 32cm)
  6. Z-endstop (blue 25cm)
  7. X-endstop (red 50cm)
  8. Hotend-thermistor (blue 60cm)
  9. Hotend-resistor (red 60cm)
  10. Hotend-fan (red/black 60cm)
  11. Bed-thermistor (blue 30-35cm)
  12. Bed-peltier
Finish by the bed wires (peltier and thermistor), as they will move they need to be above all the other wires.
<videoflash>HCyQjKg8jjU|320|240</videoflash>
The following wiring diagram of the Azteeg X1 board might help if you can't read the inscription on the board. X1 wiring diagram.jpg
Y-axis (105mm between smooth rods)
principle of the y-axis, linear bearing or bushing version
File:Foldarap y-axis sliders principle.jpg
principle of the printed sliders version (in progress)
Smooth-rod-300mm.jpg x2
<videoflash>CvJv414KFWM|320|240</videoflash>
X-axis (30mm between smooth rods)
X-ends
FoldaRap x-motor.jpg X-motor FoldaRap extruder-idler2.jpg extruder-idler
if the bolt don't screw in the plastic, add a nut, but this one can be tricky to put in place.
detail of the bearing idler
Foldarap X-end idler.jpg x1 M3x8.jpg x2 M3 nut.jpg x3
M3 washer.jpg x4-6 M3x12.jpg x2 623zz.jpg x1
M3x16.jpg x1 Fan 40mm.jpg x1
<videoflash>XdfJH7XhZbk|320|240</videoflash>
After wiring, put the two x-ends in place (impregnate the printed parts with oil for better sliding) and add the smooth-rod without forgetting the three linear bearings.
X-carriage
Foldarap X-carriage.jpg x1 Smooth-rod-300mm.jpg x2 LM6UU.jpg x3 (LM6UU or igus RJMP-01-06)
<videoflash>mGf8y23Vfdc|320|240</videoflash>
Top Frame
Foldarap z-top-left.jpg x1 Foldarap z-top-right.jpg x1 20x20 200mm.jpg x1 Reprap-org plate 160mm.jpg x1
<videoflash>|320|240</videoflash>
<videoflash>xOSs5n_cQY4|320|240</videoflash>
Setting the Z-sliders (242mm between threaded rods)
M5 nut.jpg x4 230-235mm threaded-rod.jpg x2
  • turn the rods in the x-ends to push them in the vinyl coupling
<videoflash>iZKFV5miQEk|320|240</videoflash>
X-axis 2/2
<videoflash>0r0LzsToHcs|320|240</videoflash>
  • Now you can add some tension to the x-belt
<videoflash>sVjxMQwowbg|320|240</videoflash>
Foldarap reprappro-hotend.jpg hotend M3x20.jpg x4 M3 nut.jpg x4
  • 700mm belt
  • zip-tie x2
<videoflash>yqNI2H22ZcY|320|240</videoflash>
Tidying
  • spiral wrapping band : for the wires that came out of the base (30cm left / 57cm right).
<videoflash>CdsBjoGTuLI|320|240</videoflash> <videoflash>j3T9N8Ssmpc|320|240</videoflash>
Leveling the bed and zeroing
The Z-zero is made when leveling the bed.
  1. Start by roughly leveling it
  2. then move the nozzle to the lowest point
  3. and adjust the 3 screws to level it regarding that height (by turning them until the homing move stop lowering the springs)
  4. repeat on each corners so the zero is exactly when the nozzle stop touching the bed (true for the four corners+center)
    1. I like to start with the X direction (from the middle of the two left-screws to the right screw)
    2. then only working on the left side, trying alternatively from the front to the end corner
    3. after that it's supposed to be leveled but may need few more tweaking for the right corners
  • Skeinforge : you will only have to add a little offset (altitude), to have the desired height for the first layer, usually the same as your layer height.
  • Slic3r : leave z-offset at 0, it will add one layer height automatically (you still may have to adjust it slightly to fine tune the Z-zero).
Another advantage of that : by moving to the center of the bed from the zero height, the nozzle is also wiped by the side of the bed from any purged plastic
Go go go first print !!!
