G-code
Revision as of 14:06, 19 May 2015 by Phd0 (talk | contribs) (G22 & G23: Firmware controlled Retract/Precharge)
This page tries to describe the flavour of G-codes that the RepRap firmwares use and how they work. The main target is additive fabrication using FFF/FDM processes. Codes for print head movements follow the NIST RS274NGC G-code standard, so RepRap firmwares are quite usable for CNC milling and similar applications, too.
There are a few different ways to prepare GCode for a printer. One is to use a slicer like Slic3r, Skeinforge or Cura. These programs take a CAD model, slice it into layers, and output the GCode required for each layer. Slicers are the easiest way to go from a 3D model to a printed part, but the user sacrifices some flexibility when using them. Another option for GCode generation is to use a lower level library like mecode. Libraries like mecode give you precise control over the tool path, and thus are useful if you have a complex print that is not suitable for naive slicing. The final option is to just write the GCode yourself. This may be the best choice if you just need to run a few test lines while calibrating your printer.
As many different firmwares exist and their developers tend to implement new features without discussing strategies or looking what others did before them, a lot of different sub-flavours for the 3D-Printer specific codes developed over the years.
Introduction
N3 T0*57
N4 G92 E0*67
N5 G28*22
N6 G1 F1500.0*82
N7 G1 X2.0 Y2.0 F3000.0*85
N8 G1 X3.0 Y3.0*33
Gcode can also be stored in files on SD cards. A file containing RepRap Gcode usually has the extension .g, .gco or .gcode. Files for BFB/RapMan have the extension .bfb. Gcode stored in file or produced by a slicer might look like this:
G92 E0
G28
G1 F1500
G1 X2.0 Y2.0 F3000
G1 X3.0 Y3.0
Support Marlin RepRapFirmware Klipper Prusa Buddy Repetier Smoothie Druid MK4duo
Partial ??? ??? ??? ??? Experimental depreciated ??? ???
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa MakerBot
??? No ??? Yes ??? ??? automatic ??? ???
Here means:
{{yes}}
The Gcode is fully supported by the firmware.
{{partial}} or {{experimental}}
There is some support for the Gcode. Often it is required to check out the source code branch for the firmware (usually stored in a different branch) or to flip configuration switches on the mainboard.
automatic
The firmware handles this Gcode automatically, so there's no need to send the command. An example is power supply on/off Gcode (M80/M81) in the Teacup firmware.
It is unknown if the firmware supports this Gcode. You may want to test this yourself before using it in production.
{{no}}
The firmware does not support this Gcode.
depreciated
The firmware depreciated this Gcode. The firmware author(s) should amend the depreciated Gcode on this page with workarounds (if needed) and the last supported firmware version that will accept this Gcode.
Fields
A RepRap Gcode is a list of fields that are separated by white spaces or line breaks. A field can be interpreted as a command, parameter, or for any other special purpose. It consists of one letter directly followed by a number, or can be only a stand-alone letter (Flag). The letter gives information about the meaning of the field (see the list below in this section). Numbers can be integers (128) or fractional numbers (12.42), depending on context. For example, an X coordinate can take integers (X175) or fractionals (X17.62), but selecting extruder number 2.76 would make no sense. In this description, the numbers in the fields are represented by nnn as a placeholder.
Letter Meaning
Tnnn Select tool nnn. In RepRap, tools are extruders
Hnnn Parameter - used for heater number in PID Tuning
Ennn Length of extrudate. This is exactly like X, Y and Z, but for the length of filament to extrude. It is common for newer stepper based systems to interpret ... Better: Skeinforge 40 and up interprets this as the absolute length of input filament to consume, rather than the length of the extruded output.
Comments
Gcode comments begin at a semicolon, and end at the end of the line:
N3 T0*57 ; This is a comment
N4 G92 E0*67
; So is this
N5 G28*22
Special fields
N: Line number
Yes ??? ??? ??? ??? Yes ??? ??? ???
 ? Yes ??? Yes ??? ??? Yes ??? ???
Example: N123
If checking is supported, the RepRap firmware expects line numbers to increase by 1 each line, and if that doesn't happen it is flagged as an error. But you can reset the count using M110 (see below).
*: Checksum
Example: *71
If checking is supported, the RepRap firmware checks the checksum against a locally-computed value and, if they differ, requests a repeat transmission of the line of the given number.
Checking
??? Yes ??? Yes ??? ??? Yes ??? ???
The RepRap firmware checks the line number and the checksum. You can leave both of these out - RepRap will still work, but it won't do checking. You have to have both or neither though. If only one appears, it produces an error.
int cs = 0;
   cs = cs ^ cmd[i];
Buffering
??? ??? ??? Yes ??? ??? Yes ??? ???
G-commands
G0 & G1: Move
Yes Yes ??? ??? ??? Yes Yes ??? ???
Yes Yes Yes Yes No ??? Yes ??? Yes
Usage
Parameters
Not all parameters need to be used, but at least one has to be used
Snnn Flag to check if an endstop was hit (S1 to check, S0 to ignore, S2 see note, default is S0)1
Examples
G0 X12 (move to 12mm on the X axis)
G0 F1500 (Set the feedrate to 1500mm/minute)
G1 X90.6 Y13.8 E22.4 (Move to 90.6mm on the X axis and 13.8mm on the Y axis while extruding 22.4mm of material)
1. G1 F1500
2. G1 X50 Y25.3 E22.4
In the above example, we set the feedrate to 1500mm/minute on line 1, then move to 50mm on the X axis and 25.3mm on the Y axis while extruding 22.4mm of filament between the two points.
1. G1 F1500
2. G1 X50 Y25.3 E22.4 F3000
However, in the above example, we set a feedrate of 1500 mm/minute on line 1, then do the move described above accelerating to a feedrate of 3000 mm/minute as it does so. The extrusion will accelerate along with the X and Y movement, so everything stays synchronized.
The RepRap spec treats the feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over the acceleration and deceleration of the printer head in such a way that ensures that everything moves smoothly together, and the right volume of material is extruded at all points.3
Notes
1Some firmwares allow for the RepRap to enable or disable the "sensing" of endstops during a move. Please check with whatever firmware you are using to see if they support the S parameter in this way, as damage may occur if you assume incorrectly. In the dc42 fork of RepRapFirmware, using the S1 or S2 parameter on a delta printer causes the XYZ parameters to refer to the individual tower motor positions instead of the head position, and to enable endstop detection as well if the parameter is S1.
4zpl and dc42 forks of RepRapFirmware implement an additional 'R1' parameter to tell the machine to go back to the coordinates a print was originally paused at.
G2 & G3: Controlled Arc Move
Yes1 No ??? ??? ??? Yes Yes ??? ???
Yes Yes No No No ??? No ??? ???
Usage
Parameters
Examples
G2 X90.6 Y13.8 I5 J10 E22.4 (Move in a Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
G3 X90.6 Y13.8 I5 J10 E22.4 (Move in a Counter-Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
Notes
1The Marlin Firmware can toggle support for these Gcodes. To enable support, make sure to define SCARA at compile time, or else the Gcodes will be ignored.
G28: Move to Origin (Home)
Yes Yes Yes Yes Yes ??? Yes ??? Yes
Parameters
This command can be used without any additional parameters.
Examples
G28 (Go to origin on all axes)
G28 X Z (Go to origin only on the X and Z axis)
When the RepRap firmware receives this command, it moves all (or the supplied) axis's back to the zero endstops as quickly as it can, then backs off by a millimeter and slowly moves back to the zero endstop activation points to increase position accuracy. This process is also known as "Homing".
If you add coordinates, these coordinates are ignored. For example, G28 Z0.00 results in the same behaviour as G28 Z.
When Duet-dc42 firmware is used to control a delta printer, any G28 command will home all three towers, regardless of any XYZ letters.
G29: Detailed Z-Probe
Yes No ??? ??? ??? Yes No ??? ???
??? No No No Yes ??? No ??? ???
Example: G29
Probes the bed at 3 or more points. The printer must be homed with G28 before G29.
G29.1: Set Z probe head offset
No No ??? ??? ??? No No ??? ???
Example: G29.1 X30 Y20 Z0.5
G29.2: Set Z probe head offset calculated from toolhead position
Example: G29.2 Z0.0
The user would typically place the toolhead at the zero point of the axis and issue the G29.2 command.
G30: Single Z-Probe
Some implementations allow more general behaviour: if a Pn field is specified the probed X, Y, and Z values are saved as point n on the bed for calculating the offset plane. Generally n is 0, 1, or 2. If X, or Y, or Z values are specified (e.g. G30 P1 X20 Y50 Z0.3) then those values are used instead of the machine's current coordinates. A silly Z value (less than -9999.0) causes the machine to probe at the current point to get Z, rather than using the given value. If an S field is specified (e.g. G30 P1 Z0.3 S) the bed plane is computed for compensation and stored. The combination of these options allows for the machine to be moved to points using G1 commands, and then probe the bed, or for the user to position the nozzle interactively and use those coordinates. The user can also record those values and place them in a setup GCode file for automatic execution.
The dc42 variant of RepRapFirmware uses the value of the S parameter to specify what computation to perform. If the value is -1 then the Z offsets of all the points probed are printed, but no calibration is done. If the value is zero or not present, then this specified that the number of factors to be calibrated is the same as the number of points probed. Otherwise, the value indicates the number of factors to be calibrated, which must be no greater than the number of points probed. Currently (as of version 1.04d), the number of factors may be 3, 4 or 5 when doing auto bed compensation on a Cartesian or CoreXY printer, and 3, 4, 6 or 7 when doing auto calibration of a Delta printer.
G31: Report Current Probe status
No Yes ??? ??? ??? ??? Yes ??? ???
??? No No No No ??? No ??? ???
In Duet-dc42 firmware, separate G31 parameters may be defined for probe types 0, 1/2, and 3 (probe types 1 and 2 share the same set of parameters). To specify which probe you are setting parameters for, send a M558 command to select the probe type before sending the G31 command.
Duet-dc42 firmware supports additional parameters S (bed temperature in degC at which the specified Z parameter is correct, default is current bed temperature) and C (temperature coefficient of Z parameter in mm/degC, default zero). This is useful for ultrasonic and other probes that are affected by temperature.
Duet-dc42 firmware versions 1.00b onwards also allow the X and Y offsets of the Z probe relative to the print head (i.e. the position when the empty tool is selected) to be specified, by adding parameters X and Y. This allows you to calculate your M557 probe coordinates based on the geometry of the bed, without having to correct them for Z probe X and Y offset. It also provides more accurate bed compensation.
No: See G29 Yes ??? ??? ??? ??? Yes ??? ???
Probes the bed at 3 or more pre-defined points (see M557) and updates transformation matrix for bed leveling compensation. Later versions of RepRapFirmware execute macro file bed.g if present instead of using the M557 coordinates.
G31: Dock Z Probe sled
Yes No ??? ??? ??? ??? No ??? ???
G32: Undock Z Probe sled
G4: Dwell
??? Yes Yes Yes No ??? Yes ??? ???
Parameters
Pnnn Time to wait, in milliseconds
Snnn Time to wait, in seconds (Only on Marlin and Smoothie)
Example
G4 P200
On Marlin and Smoothie, the "S" parameter will wait for seconds, while the "P" parameter will wait for milliseconds. "G4 S2" and "G4 P2000" are equivalent.
G10: Tool Offset
No Yes ??? ??? ??? No No ??? ???
Example: G10 P3 X17.8 Y-19.3 Z0.0 R140 S205
This sets the offset for tool (or in older implementations extrude head) 3 (from the P3) to the X and Y values specified. You can put a non-zero Z value in as well, but this is usually a bad idea unless the tools are loaded and unloaded by some sort of tool changer. When all the tools are in the machine at once they should all be set to the same Z height.
Remember that any parameter that you don't specify will automatically be set to the last value for that parameter. That usually means that you want explicitly to set Z0.0.
The NIST G-code standard mentions an additional L parameter, which is ignored.
This command is subject to discussion.
Note that Marlin and Smoothie use G10/G11 for executing a retraction/unretraction move. The RepRapPro version of Marlin supports G10 for tool offset.
Duet-zpl allows tool heaters to be switched off if the absolute negative temperature (-273.15) is passed as active and standby temperature. In this case the current active and standby temperatures are not affected.
G10 P1 R-273.15 S-273.15
G10: Retract
Yes No ??? ??? ??? Yes: 0.92 Yes ??? ???
Parameters
Snnn retract length (S1 = long retract, S0 = short retract = default) (Repetier only)
Example
G10
Retracts filament according to settings of M207 (Marlin) or accoridng to the S value (Repetier).
G11: Unretract
Parameters
Example
G11
Unretracts/recovers filament according to settings of M208 (Marlin) or accoridng to the S value (Repetier).
G20: Set Units to Inches
No Yes ??? ??? ??? Yes Yes ??? ???
??? Yes No Yes No ??? Yes ??? ???
Example: G20
G21: Set Units to Millimeters
Yes Yes Yes Yes No ??? Yes ??? ???
Example: G21
No ??? ??? ??? ??? No No ??? ???
Usage
G22 ; Retract
G23 ; Unretract/Precharge
Relying on machine's firmware to execute extrusion retract/precharge move, instead of having slicer generating to E axis G1 movement. The retract/precharge length, velocity is handled by the machine firmware.
G38.x Straight Probe
Yes ??? ??? ??? ??? ??? ??? ??? ???
Example: G90
Example: G91
G92: Set Position
Parameters
Xnnn new X axis position
Ynnn new Y axis position
Znnn new Z axis position
Ennn new extruder position
Example
G92 X10 E90
No No ??? ??? ??? Yes: 0.92 No ??? ???
Parameters
X Flag to set floor for X axis
Y Flag to set floor for Y axis
Z Flag to set floor for Z axis
Rnnn Radius to add
Examles
G100 X Y Z (set floor for argument passed in. Number ignored and may be absent.)
G100 R5 (Add 5 to radius. Adjust to be above floor if necessary)
G100 R0 (Set radius based on current z measurement. Moves all axes to zero)
Example: G130 X10 Y18 Z15 A20 B12
G131: Remove offset
No No ??? ??? ??? Yes: 0.91 No ??? ???
G133: Measure steps to top
G161: Home axes to minimum
??? No No No No ??? Yes ??? ???
Parameters
Example
G161 X Y Z F1800
Instruct the machine to home the specified axes to their minimum position. Same as G28 in other firmwares.
G162: Home axes to maximum
??? No No No No ??? Yes ??? Yes
Parameters
Example
G162 X Y Z F1800
M-commands
Yes Yes ??? ??? ??? No No ??? ???
??? No No Yes No ??? ??? ??? ???
Parameters
Snnn Time to wait, in seconds (Only on Marlin)
Example
M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller. See also M1, M112.
The Marlin Firmware does wait for user to press a button on the LCD, or a specific time. "M0 P2000" waits 2000 milliseconds "M0 S2" waits 2 seconds
M1: Sleep or Conditional stop
??? No No No No ??? ??? ??? ???
Example
M1
M2: Program End
No ??? ??? ??? ??? No ??? ??? ???
Example: M2
No No ??? ??? ??? No Yes ??? ???
Example: M3 S4000
Example: M4 S4000
No ??? ??? ??? ??? No Yes ??? ???
Example: M5
The spindle is turned off.
M6: Tool change
Example: M6
Example: M7
Example: M8
Example: M9
M10: Vacuum On (CNC specific)
Example: M10
Example: M11
Yes ??? ??? ??? ??? No Yes ??? ???
Example: M17
Yes Yes ??? ??? ??? No Yes ??? ???
Example: M18
RepRapFirmware allows stepper motors to be disabled selectively. For example, M18 X E0:2 will disable the X, extruder 0 and extruder 2 motors.
M20: List SD card
??? Yes No No No ??? No ??? ???
Example: M20
ok Files: {SQUARE.G,SQCOM.G,}
Duet-dc42 firmware returns the (long) filenames in the correct case. If the S2 parameter is present, the file list is returned in JSON format as a single array called "files", and the directory is returned in variable "dir". The optional P parameter specifies the directory to list, defaulting to the /gcodes directory in RepRapFirmware - for other firmware, this is whatever directory printable gcode files are normally stored in.
M21: Initialize SD card
Yes No ??? ??? ??? Yes Yes ??? ???
Example: M21
The SD card is initialized. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialized for the other SD functions to work.
M22: Release SD card
Example: M22
M23: Select SD file
Example: M23 filename.gco
Duet-dc42 firmware supports long filenames as well as 8.3 format.
M24: Start/resume SD print
Example: M24
When this command is used to resume a print that was paused, the dc42 and zpl forks of RepRapFirmware run macro file resume.g if it exists prior to resuming the print.
M25: Pause SD print
Example: M25
Prior to pausing, the dc42 and zpl forks of RepRapFirmware run macro file pause.g if it exists. This allows the head to be moved away from the print, filament to be retracted, etc.
M26: Set SD position
Yes ??? ??? ??? ??? Yes aborts ??? ???
Example: M26
M27: Report SD print status
Yes ??? ??? ??? ??? Yes Yes ??? ???
Example: M27
Report SD print status.
M28: Begin write to SD card
Example: M28 filename.gco
M29: Stop writing to SD card
Yes ??? ??? ??? ??? Yes No ??? ???
Example: M29 filename.gco
Example: M30 filename.gco
filename.gco is deleted.
Yes ??? ??? ??? ??? No No ??? ???
Example: M31
The response looks like:
 echo:54 min, 38 sec
(Can be used when printing from SD card)
Example: M32 filename.gco
M33
Used by some variants of Marlin firmware. Purpose unknown.
M34
M36: Return file information
No dc42 ??? ??? ??? No No ??? ???
Example: M36 filename.gco
If the file name parameter is not supplied and a file on the SD card is currently being printed, then information for that file is returned including additional field "fileName". This feature is used by the web interface any by PanelDue, so that if a connection is made when a file is already being printed, the name and other information about that file can be shown.
M37: Simulation mode
M37 S1 enters simulation mode. All G and M codes will not be acted on, but the time they take to execute will be calculated.
M37 S0 leaves simulation mode.
M40: Eject
See also M240 and M241 below.
M41: Loop
Example: M41
M42: Stop on material exhausted
Example: M42
If your RepRap can detect when its material runs out, this decides the behaviour when that happens. The X and Y axes are zeroed (but not Z), and then the machine shuts all motors and heaters off. You have to press reset to reactivate the machine. In other words, it parks itself and then executes an M0 command (q.v.).
M42: Switch I/O pin
Example: M42 P7 S255
Example: M43
Parameters
Pnnn number of points
Xnnn position on the X axis
Ynnn position on the Y axis
Vnnn verbosity
E engage
Lnnn legs of travel
As with G29, the E flag causes the probe to stow after each probe.
M70: Display message
No: See M117 ??? ??? ??? ??? No ??? ??? ???
??? No No No No ??? No ??? Yes
Example: M70 P200 Message
Instruct the machine to display a message on it's interface LCD. P is the time to display message for.
M72: Play a tone or song
No: See M300 ??? ??? ??? ??? No No ??? ???
Example: M72 P2
M73: Set build percentage
Example: M73 P50
Instruct the machine that the build has progressed to the specified percentage. The machine is expected to display this on it's interface board. If the percentage is exactly 0, then a Build Start Notification is sent. If the percentage is exactly 100, then a Build End notification is sent.
M80: ATX Power On
Yes dc42 ??? ??? ??? Yes No ??? ???
??? Yes No No No ??? automatic ??? ???
Example: M80
Note: some firmwares, like Teacup, handle power on/off automatically, so this is redundant there. Also, see RAMPS wiring for ATX on/off
M81: ATX Power Off
Example: M81
??? Yes No No No ??? Yes ??? ???
Example: M82
makes the extruder interpret extrusion as absolute positions.
Example: M83
makes the extruder interpret extrusion values as relative positions.
M84: Stop idle hold
Example: M84
On Marlin and Repetier, M84 can also be used to configure or disable the idle timeout. For example, "M84 S10" will idle the stepper motors after 10 seconds of inactivity. "M84 S0" will disable idle timeout; steppers will remain powered up regardless of activity.
M85: Set inactivity shutdown timer
Example: M85 S30
M92: Set axis_steps_per_unit
Example: M92 X<newsteps> Sprinter and Marlin
M93: Send axis_steps_per_unit
??? ??? ??? ??? ??? ??? No ??? ???
M98: Call Macro/Subprogram
Example: M98 Pmymacro.g
Runs the macro in the file mymacro.g. In conventional G Codes for CNC machines the P parameter normally refers to a line number in the program itself (P2000 would run the Macro starting at line O2000, say). For RepRap, which almost always has some sort of mass storage device inbuilt, it simply refers to the name of a GCode file that is executed by the G98 call. That GCode file does not need to end with an M99 (return) as the end-of-file automatically causes a return. Macro calls cannot usually be nested or be recursive; i.e. you can't call a macro from a macro (though some implementations may allow this).
RepRapFirmware-dc42 and RepRapFirmware-zpl support nested macros and allow the filename to include a path. The default folder is /sys.
Example: M99
Returns from an M98 call.
M98: Get axis_hysteresis_mm
Example: M98
Proposed for Marlin
M99: Set axis_hysteresis_mm
Example: M99 X<mm> Y<mm> Z<mm> E<mm>
Proposed for Marlin
??? No Yes No No ??? Yes ??? ???
in Teacup firmware: If a DC extruder is present, turn that on. Else, undo filament retraction, which means, make the extruder ready for extrusion. Complement to M103.
in BFB/RapMan firmware: Turn extruder on (forward/filament in).
in other firmwares: Deprecated. Regarding filament retraction, see M227, M228, M229.
??? No Yes No No ??? No ??? ???
In other firmwares: Deprecated.
In Teacup firmware: If a DC extruder is present, turn that off. Else, retract the filament in the hope to prevent nozzle drooling. Complement to M101.
In other firmwares: Deprecated. Regarding extruder retraction, see M227, M228, M229.
??? Yes Yes Yes Yes ??? Yes ??? ???
Parameters
Snnn Target temperature
Example
M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). Duet-dc42 and other firmware also supports the optional T parameter (as generated by slic3r) to specify which tool the command applies to. See also M109.
M104 in Teacup Firmware
Example: M104 P1 S100
Set the temperature of the device attached to the second temperature sensor to 100 °C.
Example: M105
ok T:201 B:117
M105 X0
Duet-dc42 extension
Duet-dc42 firmware returns a JSON-formatted response if parameter S2 or S3 is included. This is used by the touch-screen control panel. Additionally, parameter Rnn may be provided, where nn is the sequence number of the most recent G-code response that the client has already received.
The response comprises a single JSON object, with no nesting of objects or arrays, followed by newline. It is similar to the object returned by the web interface status request, but some fields are omitted. Here is a sample response when S2 is used:
{"status":"I","heaters":[25.0,29.0,28.3],"active":[-273.1,0.0,0.0],"standby":[-273.1,0.0,0.0],"hstat":[0,2,1],"pos":[-11.00,0.00,0.00],"extr":[0.0,0.0],"sfactor":100.00,
 "efactor":[100.00,100.00],"tool":1,"probe":"535","fanRPM":0,"homed":[0,0,0],"fraction_printed":0.572}
The meaning of these fields is:
status:  I=idle, P=printing from SD card, S=stopped (i.e. needs a reset), C=running config file, A=paused, D=pausing, R=resuming, B=busy (running a macro)
hstat:   status of the heaters, 0=off, 1=standby, 2=active, 3=fault
pos:     the X, Y and Z positions of the print head
efactor: the current extrusion factors (see M221 command)
tool:    the selected tool number. Zero typically means no tool selected.
probe:   the Z-probe reading
fanRPM:  the cooling fan RPM
homed:   the homed status of the X, Y and Z axes (or towers on a delta). 0=axis has not been homed so position is not reliable, 1=axis has been homed so position is reliable.
timesLeft: an array of the estimated remaining print times (in seconds) calculated by different methods. These are currently based on the proportion of the file read, the proportion of the total filament consumed, and the proportion of the total layers already printed. Only present if a print from SD card is in progress.
seq:     the sequence number of the most recent G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater.
resp:    the most recent G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater.
The response when S3 is used comprises these fields plus some additional ones that do not generally change and therefore do not need to be fetched as often. The extra fields include:
M106: Fan On
Parameters
Snnn speed
Example
M106 S127
Turn on the cooling fan at half speed.
Mandatory parameter 'S' declares the PWM value (0-255). M106 S0 turns the fan off. In some implementations the pwm is specified by a real fraction: M106 S0.7.
M106 in Duet Firmware
Duet-dc42 firmware also supports an optional I parameter. If this parameter is present and greater than zero, the cooling fan output is inverted. This makes the cooling fan output suitable for feeding the PWM input of a 4-wire fan via a diode. If the parameter is present and zero or negative, the output is not inverted. If the parameter is not present, the inverted/non-inverted state remains unchanged. The default at power up is not inverted.
If the 'R' parameter is passed when using Duet-zpl firmware (0.96g+), the last-known fan value will be set. If the 'S' parameter is passed along with 'R', the firmware will not reset the last-known fan value. This may be useful for tool change macro files.
M106 in Teacup Firmware
Example: M106 P2 S255
M107: Fan Off
??? Yes Yes Yes Yes ??? No ??? ???
Deprecated in Teacup firmware. Use M106 S0 instead.
M108: Set Extruder Speed
Sets speed of extruder motor. (Deprecated in FiveD firmware, see M113)
??? Yes No Yes Yes ??? not needed ??? ???
Parameters
Example
M109 S215
M109 in Teacup
M109 in Marlin, Sprinter (ATmega port), Duet
Example: M109 S185
Duet-dc42 firmware also supports the optional T parameter (as generated by slic3r) to specify which tool the command refers to (see below).
M109 in Sprinter (4pi port)
Example: M109 S185 R240 //sets extruder temperature to 185 and waits for the temperature to be between 185 - 240.
M109 in MakerBot
Example: M109 S70 T0
M110: Set Current Line Number
No ??? ??? ??? ??? Yes Yes ??? ???
??? No No Yes No ??? not needed ??? ???
Example: M110 N123
M111: Set Debug Level
No Yes ??? ??? ??? Yes No ??? ???
??? No No Yes No ??? Debug ??? ???
Example: M111 S6
#define DEBUG_ECHO (1<<0)
#define DEBUG_INFO (1<<1)
#define DEBUG_ERRORS (1<<2)
M112: Emergency Stop
??? No No Yes No ??? Yes ??? ???
Example: M112
M113: Set Extruder PWM
??? No No Yes No ??? No ??? ???
Example: M113
M113 S0.7
M114: Get Current Position
Example: M114
Yes Yes ??? ??? ??? Yes No ??? ???
Example: M115
sample data from firmware:
M116: Wait
Example: M116
Duet-dc42 firmware version 0.78c and later supports an optional P parameter, used to specify a tool number. If this parameter is present, then the system only waits for temperatures associated with that tool to arrive at their set values. This is useful during tool changes, to wait for the new tool to heat up without necessarily waiting for the old one to cool down fully.
Users of Duet-zpl may specify a list of the heaters to be waited for by specifying an 'H' parameter. Duet-zpl v1.08d+ further supports an additional 'C' parameter to wait for the chamber temperature to be reached.
M117: Get Zero Position
Example: M117
M117: Display Message
Yes dc42 ??? ??? ??? Yes Yes ??? ???
Example: M117 Hello World
This causes the given message to be shown in the status line on an attached LCD. The above command will display Hello World.
M118: Negotiate Features
Example: M118 P42
M119: Get Endstop Status
Example: M119
M120: Push
No Yes ??? ??? ??? No Yes ??? ???
  1. Current feedrate, and
M121: Pop
Yes No ??? ??? ??? No No ??? ???
M122: Diagnose
M123: Tachometer value
M124: Immediate motor stop
Immediately stops all motors.
M126: Open Valve
??? No No Yes No ??? No ??? Yes
Example: M126 P500
M126 in MakerBot
Example: M126 T0
M127: Close Valve
Example: M127 P400
M127 in MakerBot
Example: M127 T0
M128: Extruder Pressure PWM
??? ??? ??? ??? ??? No No ??? ???
Example: M128 S255
M129: Extruder pressure off
Example: M129 P100
M130: Set PID P value
No: See M301 No ??? ??? ??? No No: See M301 ??? ???
Parameters
Pnnn heater number
Snnn proportional (Kp)
Example
M130 P0 S8.0  ; Sets heater 0 P factor to 8.0
M131: Set PID I value
Parameters
Pnnn heater number
Snnn integral (Ki)
Example
M131 P1 S0.5  ; Sets heater 1 I factor to 0.5
M132: Set PID D value
No: See M301 ??? ??? ??? ??? No No: See M301 ??? ???
Parameters
Pnnn heater number
Snnn derivative (Kd)
Example
M132 P0 S24  ; Sets heater 0 D factor to 24.0
M132 in MakerBot
Example: M132 X Y Z A B
M133: Set PID I limit value
Parameters
Pnnn heater number
Snnn integral limit (Ki)
Example
M133 P1 S264  ; Sets heater 1 I limit value to 264
M133 in MakerBot
Example: M133 T0 P500
Instruct the machine to wait for the toolhead to reach its target temperature. T is the extruder to wait for. P if present, sets the time limit.
No No ??? ??? ??? No No: See M504 ??? ???
Example: M134
M134 in MakerBot
Example: M134 T0 P500
M135: Set PID sample interval
Example: M135 S300
M135 in MakerBot
Example: M135 T0
??? No No No No ??? Debug ??? ???
Example: M136 P1 # print heater 0 PID parameters to host
??? Yes No Yes Yes ??? Yes ??? ???
Parameters
Example
M140 S55
Duet-zpl allows the bed heater to be switched off if the absolute negative temperature (-273.15) is passed as active temperature. In this case the current active temperature is not affected:
M140 S-273.15
No zpl ??? ??? ??? No No ??? ???
Example: M141 S30
Duet-zpl 1.08d+ implements M141 and accepts an additional 'H' parameter to set the chamber heater number.
M142: Holding Pressure
Example: M142 S1
M143: Maximum hot-end temperature
Example: M143 S275
M144: Stand By Your Bed
Example: M144
M146: Set Chamber Humidity
Parameters
Example
M146 R60
M149: Set temperature units
Parameters
Example
M149 K
M150: Set display color
Parameters
Rnnn red
Unnn green
Bnnn blue
Example
M150 R255 U128 B192
Set BlinkM Color via I2C. Range for values: 0-255
Example: M160 S4
M160 S4
G1 X70.6 E0:0:0:42.4
G1 E42.4:0:0:0
Parameters
Snnn extruder number
Pnnn weight
M164: Store weights
Parameters
Snnn virtual extruder number
??? Yes No No Yes ??? No: See M116 ??? ???
Parameters
Example
M190 S60
Example: M191 P60
M200: Set filament diameter
M200 D0 or M200 D1.128 ; reset E multiplier to 1, since sqrt(1/pi)*2=1.128
Example: M201 X1000 Y1000 Z100 E2000
??? ??? No No No ??? No ??? ???
M203: Set maximum feedrate
Example: M203 X6000 Y6000 Z300 E10000
Sets the maximum feedrates that your machine can do in mm/min.
M203 Repetier
Set temperture monitor to Sx.
P = Printing moves
The command "M204 P800 T3000 R9000" set the acceleration for printing movements to 800mm/s^2, for travels to 3000mm/s^2 and for retracts to 9000mm/s^2.
M204 Repetier
M204 X[Kp] Y[Ki] Z[Kd] -
M205: Advanced settings
M205 Repetier
Output EEPROM settings.
M206:
M206 Marlin, Sprinter, Smoothie - Set home offset
Example: M206 X10.0 Y10.0 Z-0.4
M206 Repetier - Set eeprom value
Example: M206 T3 P39 X19.9
Set Jerk to 19.9
Support Marlin RepRapFirmware Klipper Prusa Buddy Repetier Smoothie Druid MK4duo
No ??? ??? ??? ??? ??? No ??? ???
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa MakerBot
Example: M207
M207: Set retract length
Parameters
Fnnn feedrate, in mm/min
Znnn additional zlift/hop
Example
M207 S4.0 F2400 Z0.075
Sets retract length, stays in mm regardless of M200 setting
M208: Set axis max travel
Example: M208 X250 Y210 Z180
With Duet-dc42 firmware, on a Cartesian printer you can also use this command to specify software limits for axis travel in the negative direction, by adding parameter S1. The axis limits you set are also the positions assumed when an endstop is triggered.
M208: Set unretract length
Yes No ??? ??? ??? No Yes ??? ???
Parameters
Fnnn feedrate, in mm/sec
Example: M209 S1
M210: Set homing feedrates
Example: M210 X1000 Y1500
Example: M211 X1 Y1 Z1 S0
Disables X,Y,Z max endstops
Example: M211 X0 S1
Enables X min endstop
Example: M211
Yes* ??? ??? ??? ??? No No ??? ???
Example: M212 Z-0.2
M218: Set Hotend Offset
Example: M218 T1 X50 Y0.5
Example: M220 S80
S<factor in percent>- set speed factor override percentage
Example: M221 S70
S<factor in percent>- set extrude factor override percentage
M220: Turn off AUX V1.0.5
M221: Turn on AUX V1.0.5
M226: Gcode Initiated Pause
??? No Yes No Yes ??? No ??? ???
Example: M226
M226: Wait for pin state
Parameters
Pnnn pin number
Snnn pin state
Example
M226 P2 S1
Example: M227 P1600 S1600
P and S are steps.
Example: M228
See also M227.
Example: M229 P1.0 S1.0
Example: M230 S1
M231: Set OPS parameter
No ??? ??? ??? ??? Yes No ??? ???
M231 S[OPS_MODE] X[Min_Distance] Y[Retract] Z[Backslash] F[ReatrctMove]
M240: Trigger camera
Example: M240
Triggers a camera to take a photograph. (Add to your per-layer GCode.)
??? No No No No ??? Debug: Echo off ??? ???
Example: M240
??? No No No No ??? Debug: Echo on ??? ???
Example: M241
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
M250: Set LCD contrast
Example: M250 C20
M251 S0 - Reset, S1 - Print, S2 - Store to Z length (also EEPROM if enabled)
(This is a Repetier-Firmware only feature)
M280: Set servo position
Yes ??? ??? ??? ??? ??? No ??? ???
(Marlin, Repetier M340)
Set servo position absolute. P: servo index, S: angle or microseconds (Marlin)
M300: Play beep sound
Parameters
Snnn frequency in Hz
Pnnn duration in milliseconds
Example
M300 S300 P1000
Play beep sound, use to notify important events like the end of printing. See working example on R2C2 electronics. Also supported by duet-dc42 firmware via the sounder on the add-on touch screen control panel.
M301: Set PID parameters
??? Yes No No No ??? No: See M13[0-3]) ??? ???
Parameters
Hnnn heater number
Pnnn proportional (Kp)
Innn integral (Ki)
Dnnn derivative (Kd)
Examples
M301 H2 P1 I2 D3 ; Marlin (hot end only; see M304 for bed PID)
M301 H1 P1 I2 D3 C5 H1 B20 W127 ; RepRapFirmware
M301 P1 I2 D3 T0.2 H1 B20 W127 S0.8 ; Duet-dc42
M301 S0 P30 I10 D10 ; Smoothie ( S0 is 0 for the hotend, and 1 for the bed, other numbers may apply to your configuration, depending on the order in which you declare temperaturecontrol modules )
Sets Proportional, Integral and Derivative values for hot end. The value C refers to an extrusion rate. The value T is the approximate additional PWM (on a scale of 0 to 255) needed to maintain each additional 1C temperature, used to preset the I-accumulator when switching from heater fully on/off to PID. H is the heater number, default 1 (i.e. first extruder heater; the H parameter is compulsory for RepRapFirmware).
Duet-dc42 and RepRap firmware interprets a negative P term as indicating that bang-bag control should be used instead of PID (not recommended for the hot end, but OK for H0 which is the bed heater). The S factor is designed to allow a correction to be made for a change in heater power and/or power supply voltage without having to change all the other parameters. For example, an S factor of 0.8 means that the final output of the PID controller should be scaled to 0.8 times the standard value, which would compensate for a heater that is 25% more powerful than the standard one or a supply voltage that is 12.5% higher than standard.
See also PID Tuning.
Alternate implementation
Example: M301 W125
M302: Allow cold extrudes
Yes Yes ??? ??? ??? Yes: 0.92 No ??? ???
This tells the printer to allow movement of the extruder motor, when the hotend is not at printing temperature
Example: M302
When using RepRapFirmware, running M302 will only report the current cold extrusion state. To allow or deny cold extrudes/retracts, run either "M302 P1" or "M302 P0".
M303: Run PID tuning
Hot end usage:
M303 S<temperature> C<cycles>
Bed usage:
Example:
M303 C8 S175
M303 E0 S190
Yes dc42 ??? ??? ??? ??? No: See M301 ??? ???
Parameters
Innn integral (Ki)
Examples
M304 P1 I2 D3 ; set kP=3, kI=2, kD=3
M301 P1 I2 D3 T0.7 H0 B20 W127 ; Duet-dc42 firmware
M304  ; Report parameters
Sets Proportional, Integral and Derivative values for bed. Duet-dc42 firmware interprets a negative P term as indicating that bang-bag control should be used instead of PID. In Duet-dc42 firmware, this command is identical to M301 except that the H parameter (heater number) defaults to zero.
Example: M304 H1 B4200 R4800 T100000
Sets the parameters for temperature measurement. Supported by RepRapFirmware from 0.78c, and Duet-dc42 firmware.
Example: M305 P1 T100000 R1000 B4200
This tells the firmware that for heater 1 (P parameter: 0 = heated bed, 1 = first extruder) the thermistor 25C resistance (T parameter) is 100Kohms, the thermistor series resistance (R parameter) is 1Kohms, the thermistor beta (B parameter) is 4200. All parameters other than P are optional. If only the P parameter is given, the existing values are displayed.
Additionally, Duet-dc42 firmware supports an ADC correction functionality and a thermistor selection facility.
Example: M305 P1 T100000 R1000 B4200 H14 L-11 X2
Here the ADC high end correction (H parameter) is 14, the ADC low end correction (L parameter) is -11, and thermistor input #2 is used to measure the temperature of heater #1.
M306: set home offset calculated from toolhead position
No ??? ??? ??? ??? ??? Yes ??? ???
Example: M306 Z0
Implemented in Smoothieware
M320: Activate autolevel(Repetier)
(Repetier only)
M321: Deactivate autolevel(Repetier)
(Repetier only)
M322: Reset autolevel matrix
Example: M322 S1
Parameter S1 is mandatory
(Repetier only)
M340: Control the servos
M350: Set microstepping mode
Example: M350 S1
Sets microstepping mode. Steps per unit remains unchanged. S<mode> sets stepping mode for all drivers, B<mode> sets stepping mode for only one.
Example: M351
M355: Turn case lights on/off
No No ??? ??? ??? Yes: 0.92.2 No ??? ???
Examples
M355 S1 ; Enable lights
M355 S0 ; Disable lights
M355 ; Report status
Every call or change over LCD menu sends a state change for connected hosting software like
Case lights on
Case lights off
No case lights
No ??? ??? ??? ??? Yes: 0.92.2 No ??? ???
Target
Example
M360
Response
Config:Baudrate:250000
Config:InputBuffer:127
Config:NumExtruder:2
Config:MixingExtruder:0
Config:HeatedBed:0
Config:SDCard:1
Config:Fan:1
Config:LCD:1
Config:SoftwarePowerSwitch:1
Config:XHomeDir:-1
Config:YHomeDir:-1
Config:ZHomeDir:-1
Config:SupportG10G11:1
Config:CaseLights:0
Config:ZProbe:1
Config:Autolevel:0
Config:EEPROM:1
Config:PrintlineCache:24
Config:JerkXY:30.00
Config:JerkZ:0.30
Config:RetractionLength:3.00
Config:RetractionSpeed:40.00
Config:RetractionZLift:0.00
Config:XMin:0.00
Config:YMin:0.00
Config:ZMin:0.00
Config:XMax:250.00
Config:YMax:150.00
Config:ZMax:90.00
Config:XSize:250.00
Config:YSize:150.00
Config:ZSize:90.00
Config:XPrintAccel:250.00
Config:YPrintAccel:250.00
Config:ZPrintAccel:100.00
Config:XTravelAccel:250.00
Config:YTravelAccel:250.00
Config:ZTravelAccel:100.00
Config:PrinterType:Cartesian
Config:MaxBedTemp:120
Config:Extr.1:Jerk:50.00
Config:Extr.1:MaxSpeed:100.00
Config:Extr.1:Diameter:0.00
Config:Extr.1:MaxTemp:220
Config:Extr.2:Jerk:50.00
Config:Extr.2:MaxSpeed:100.00
Config:Extr.2:Diameter:0.00
Config:Extr.2:MaxTemp:220
Partial No ??? ??? ??? No Yes ??? ???
??? No No No No ??? No ??? ???
Experimental No ??? ??? ??? No Yes ??? ???
Smoothieware: M364 P0 will accept the current position as 90deg between arms. The offset is stored as a trim offset (M666) and no further user interaction is required except to save all changes via M500
M365: SCARA scaling factor
Usage
M370
M370 X<divisions> Y<divisions>
M374: Save calibration grid
Saves the calibration grid. (Smoothieware)
Usage
M374
M374 <file extension> Z
Without parameters safes the grid into the default grid file that gets loaded at boot Parameter specifies the extension of the grid file - useful for special grid files such as for a special print surface like a removable print plate. Addition of Z will additionally save the M206 Z homing offset into the grid file
Display the bed level calibration matrix (Marlin) Load Grid matrix file (Smoothieware)
Usage
M375
M375 <file extension>
M380: Activate solenoid
Example: M380
M381: Disable all solenoids
Example: M381
??? Yes No No Yes ??? No ??? ???
Example: M400
M401: Lower z-probe
Example: M401
Lower z-probe if present.
M402: Raise z-probe
Example: M402
Raise z-probe if present.
M404: Filament width
Example: M404 N1.75
N<dia in mm> Enter the nominal filament width (3mm, 1.75mm ) or will display nominal filament width without parameters.
M405: Filament Sensor on
Example: M405
M406: Filament Sensor off
Example: M406
Example: M407
Displays measured filament diameter.
No Partial ??? ??? ??? No No ??? ???
Report a JSON-style response by specifying the desired type using the 'S' parameter. For some purposes it is necessary to pass the sequence number, which is why Duet-zpl and Duet-dc42 accept an additional 'P' parameter to specify it.
Example: M408 S0
The following response types are supported:
  • Type 0 is the M105 S2 response, which is like the new-style status response (for the old web interface) but some fields are omitted.
  • Type 1 is the M105 S3 response, which is like the M105 S2 response except that static values are also included.
  • Type 2 is the new-style standard JSON response, which is also reported to the new web interface (see Duet Web Control)
  • Type 3 is an extended version of type 2 which includes some additional parameters that aren't expected to change very frequently
  • Type 4 is an extended version of type 2 which may be used to poll for current printer stats
  • Type 5 reports the current machine configuration
For a more detailed comparison of type 2 - 5, see http://reprap.org/wiki/Proposed_RepRap_Duet_Status_Responses
Currently M408 is only supported by Duet-dc42 and Duet-zpl.
M420: Set RGB Colors as PWM
No ??? ??? ??? ??? No No ??? ???
??? No No No Yes ??? No ??? ???
Example: M420 R255 E255 B255
M500: Store parameters in EEPROM
Yes dc42, zpl ??? ??? ??? Yes ??? ??? ???
Example: M500
Save current parameters to EEPROM. dc42 and zpl forks of RepRapFirmware allow "S1" to be passed, which forces parameters to be automatically saved to EEPROM when they are changed.
M501: Read parameters from EEPROM
Example: M501
Set the active parameters to those stored in the EEPROM. This is useful to revert parameters after experimenting with them.
M502: Revert to the default "factory settings."
Yes ??? ??? ??? ??? Yes ??? ??? ???
Example: M502
This command resets all tunable parameters to their default values, as set in the firmware. This doesn't reset any parameters stored in the EEPROM, so it must be followed with M501 if you want to do that.
M503: Print settings
Yes ??? ??? ??? ??? ??? ??? ??? ???
Example: M503
This command asks the firmware to reply with the current print settings stored in EEPROM. The reply output includes the G-Code commands to produce each setting. For example, the Steps Per Unit values are displayed as an M92 command.
M540: Enable/Disable "Stop SD Print on Endstop Hit"
Parameters
Snnn state, S1=enable, S0=disable
Example
M540 S1
M540: Set MAC address
No Yes ??? ??? ??? No No ??? ???
Example: M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED
M550: Set Name
Example: M550 PGodzilla
M551: Set Password
Example: M551 Pmy-very-secret-word
M552: Set IP address
Example: M552 P192.168.1.14
Sets the IP address of the RepRap machine to (in this case) 192.168.1.14. A restart may be required before the new IP address is used. If no P field is specified, this echoes the existing IP address configured. If S0 is added thus: M552 S0 P192.168.1.14 networking is disabled.
M553: Set Netmask
Example: M553 P255.255.255.0
Sets the network mask of the RepRap machine to (in this case) 255.255.255.0. A restart may be required before the new network mask is used. If no P field is specified, this echoes the existing network mask configured.
M554: Set Gateway
Example: M554 P192.168.1.1
Sets the Gateway IP address of the RepRap machine to (in this case) 192.168.1.1. A restart may be required before the new gateway IP address is used. If no P field is specified, this echoes the existing Gateway IP address configured.
M555: Set compatibility
Example: M555 P1
For firmware that can do it, sets the firmware to a mode where its input and (especially) output behaves exactly like other established firmware. The value of the P argument is:
P value Firmware
1 RepRap_Firmware
2 Marlin
3 Teacup
4 Sprinter
5 Repetier
M556: Axis compensation
Imaging denoting how to determine the S parameter for Gcode M556
Example: M556 S100 X0.7 Y-0.2 Z0.6
M557: Set Z probe point
Example: M557 P1 X30 Y40.5
M558: Set Z probe type
Example: M558 P0 X1 Y0 Z1
A Z probe may be a switch, an IR proximity sensor, or some other device. This selects which to use. P0 indicates that no Z probe is present. P1 gives an unmodulated IR probe, or any other probe type that emulates an unmodulated IR probe (probe output is an analog signal that rises with decreasing nozzle height above the bed). If there is a control signal to the probe, it is driven high when the probe type is P1. P2 specifies a modulated IR probe, where the modulation is commanded directly by the main board firmware using the control signal to the probe. P3 selects an alternative Z probe by driving the control signal to the probe low. P4 selects a switch (on the Duet, this must be connected to the E0 endstop pins).
The X, Y and Z parameters specify whether each axis uses the Z probe for homing or not. If the parameter is nonzero, the Z probe is used for homing that axis. if the parameter is zero, the endstop switch for that axis is used for homing instead. See also G31 and G32.
Duet-dc42 and zpl-dc42 firmware support an additional R parameter, which specifies the modulation channel. Channel 0 (the default) uses the standard Z probe modulation pin on the Duet 0.6. Channel 1 selects the alternative Z probe modulation pin on the Duet 0.7.
Duet-dc42 firmware versions 1.00e onwards supports additional parameter H. This specifies the dive height from which probing is done in response to a G30 command when the P parameter is present, or a G32 command.
Example: M559
M560: Upload web page file
Example: M560
<!-- **EoF** -->
M561: Set Identity Transform
Example: M561
M562: Reset temperature fault
Example: M562 P2
M563: Define or remove a tool
Example: M563 P3 D0:5:6 H1:3
Tools are usually (though not necessarily) extruders. The P field specifies the tool number. Tool numbers can have any positive integer value and 0. The D field specifies the drive(s) used by the tool - in this case drives 0, 5 and 6. Drive 0 is the first drive in the machine after the movement drives (usually X, Y and Z). If there is no D field the tool has no drives. The H field specifies the tool's heaters - in this case heaters 1 and 3. Heater 0 is usually the hot bed (if any) so the first extruder heater is usually 1. If there is no H field the tool has no heaters.
Tools are driven using multiple values in the E field of G1 commands, each controlling the corresponding drive in the D field above, as follows:
G1 X90.6 Y13.8 E2.24:2.24:15.89
G1 X70.6 E0:0:42.4
The first line moves straight to the point (90.6, 13.8) extruding a total of 2.24mm of filament from both drives 0 and 5 and 15.98mm of filament from drive 6.
The second line moves back 20mm in X extruding 42.4mm of filament from drive 6.
Duet-dc42 firmware supports an additional form of the M563 command. The command:
M563 S1
Duet-zpl firmware allows the deletion of existing tools if M563 is called in this way:
M563 P1 D-1 H-1
M564: Limit axes
Example: M564 S0
Allow moves outside the print volume, or not. If the S parameter is 0, then you can send G codes to drive the RepRap outside its normal working volume, and it will attempt to do so. User beware... If you set the S parameter to 1 then the RepRap will not think outside the box. The default behaviour is S = 1.
M565: Set Z probe offset
No No: See G31 ??? ??? ??? No Yes ??? ???
Example: M565 X3 Y4.5 Z-2.37
Set the offset from the extruder tip to the probe position. The X, Y and Z values are the delta between the extruder and the actual trigger position of the probe. If the probe trigger point is below the extruder (typical) the Z offset will be negative. This just records the point offset; it does not actually do the probing. See G32.
Example: M566 X20 Y20 Z2 E10
Work around an algorithm limitation of some firmwares, which can't calculate step timings for a standing start. Teacup Firmware and Smoothieware don't have this limitation, so M566 is obsolete there.
M566 sets the speeds in mm/minute that axes can do from a standing start. If an accelerating algorithm starts a move with a zero velocity on other firmwares and then accelerates from that, it can give problems when the zero initial velocity is used to calculate a timestep between stepper pulses at the beginning: the timestep ends up being infinite... So these systems have initial small velocities to start at. This sets them.
The dc42 variant of RepRapFirmware doesn't have the limitation, but instead it uses this parameter to determine the maximum allowable speed change of each motor when cornering.
M567: Set tool mix ratios
Example: M567 P2 E0.1:0.2:0.1:0.6
The example sets the mix ratio for tool 2 (the P value). When mixing is then turned on (see M568), only single E values need to be sent on a G1 command (any extra E values will be ignored, but are not illegal):
G1 X20 E1.3
See also M568.
Example: M568 P2 S0
G1 X20 E0.2:0.4:0.166:0.3
The off state is the default.
M569: Set axis direction values
Example: M569 P0 S1
Set the control value for the drive specified by P that sends it forwards to the given value in the S field. After sending the example, sending a 1 to X (drive 0) will make it go forwards, sending a 0 will make it go backwards. Obviously to be used with extreme caution...
M570: Set heater timeout
Example: M570 S120
After a heater has been switched on, wait 120 seconds for it to get close to the set temperature. If it takes longer than this, flag a heater fault.
M571: Set output on extrude
Example: M571 S0.5
This turns an output on whenever extrusion is being done, and turns it off when the extrusion is finished. The output could control a fan or a stirrer or anything else that needs to work just when extrusion is happening. The S parameter sets the value of the PWM to the output. 0.0 is off; 1.0 is fully on.
M572: Set or report extruder elasticity compensation
No dc42 ??? ??? ??? No No ??? ???
Example: M572 P3 S0.06
This sets the compensation time in seconds (S parameter) for Bowden extruder elasticity for the specified drive (P parameter). Supported by Duet-dc42 firmware. It has an effect similar to the EXTRUDER_ADVANCE_K factor in Marlin firmware. Normally, compensation should be applied to extruder drives only (drives 3 and higher).
M573: Report heater PWM
Example: M573 P1
This gives a running average (usually taken over about five seconds) of the PWM to the heater specified by the P field. If you know the voltage of the supply and the resistance of the heater this allows you to work out the power going to the heater.
Example: M574 X1 Y2 Z0 S1
This defines the type of endstop switch or opto sensor that the printer has for each axis: 0 = none, 1 = low end, 2 = high end. The optional S parameter defines whether the endstop input is active high (S1, the default) or low (S0). Intended for use with boards that provide a single endstop input for each axis that may be used for either a high or a low end endstop, such as the Duet. Supported by Duet-dc42 firmware. On delta printers, the XYZ parameters refer to the towers and the endstops should normally all be high end.
Example: M575 P1 B57600 S1
This sets the communications parameters of the serial comms channel specified by the P parameter. P0 specifies the main serial interface (typically a USB port, or serial-over-USB), while P1 specifies an auxiliary serial port (for example, the port used to connect a PanelDue). The B parameter is the required baud rate (this parameter is typically ignored if the port is a true USB port). The S parameter is a bitmap of features. The lowest bit, if set, specifies that only commands that include a valid checksum should be accepted from this comms channel.
M600: Set line cross section
No ??? ??? ??? ??? ??? ??? ??? ???
Example: M600 P0.061
Sets the cross section for a line to extrude in velocity extrusion mode. When the extruder is enabled and movement is executed the amount of extruded filament will be calculated to match the specified line cross section.
M600: Filament change pause
Example: M600
Pause for filament change X[pos] Y[pos] Z[relative lift] E[initial retract] L[later retract distance for removal].
Example: M605 S1
Sets the dual x-carriage movement mode: S<mode> [ X<duplication x-offset> R<duplication temp offset> ].
M605 S0: Full control mode. The slicer has full control over x-carriage movement M605 S1: Auto-park mode. The inactive head will auto park/unpark without slicer involvement M605 S2 [Xnnn] [Rmmm]: Duplication mode. The second extruder will duplicate the first with nnn millimeters x-offset and an optional differential hotend temperature of mmm degrees. E.g., with "M605 S2 X100 R2" the second extruder will duplicate the first with a spacing of 100mm in the x direction and 2 degrees hotter.
M665: Set delta configuration
Yes dc42 ??? ??? ??? No Yes ??? ???
Example: M665 L250 R160 S200 (Marlin), M665 L250 R160 B80 H200 (Duet-dc42)
Set the delta calibration variables. L = diagonal rod length, R = delta radius, S = segments per second, B = safe printing radius, H = nozzle height above bed when homed after allowing for the endstop corrections.
I don't think it's a good idea to have two different implementations for the same G-code, and I also question the practical value of specifying the print bed radius when defining a delta configuration, since many delta printers use a square or rectangular print bed. So perhaps we should stick to the Marlin-defined command as the definition for this command, and use a different command or set of commands to define print bed shape and size. --AndrewBCN (talk) 23:10, 31 January 2015 (PST)
The implementations are not different, they have the same L and R parameters, but each has additional parameters that are not relevant to the other implementation. I'm not against defining a new Gcode to define bed size and shape; however, you can already define the limits of a rectangular print area using M208. Even when a delta printer has a square bed, the printable area is not square. It is usually taken to be circular, although it is in reality more complicated. My purpose in adding the B parameter was to make it easy to define a radius outside which movement will not normally be attempted. I have changed "bed radius" to "safe printing radius" in the text to help clarify this. --dc42
Example M666 X-0.1 Y+0.2 Z0
M667: Select CoreXY mode
M667 S0 selects Cartesian mode (unless the printer is configured as a delta using the M665 command). Forward motion of the X motor moves the head in the +X direction. Similarly for the Y motor and Y axis, and the Z motor and Z axis. This is the default state of the firmware on power up.
M667 S1 selects CoreXY mode. Forward movement of the X motor moves the head in the +X and +Y directions. Forward movement of the Y motor moves the head in the -X and +Y directions.
M667 S2 selects CoreXZ mode. Forward movement of the X motor moves the head in the +X and +Z directions. Forward movement of the Z motor moves the head in the -X and +Z directions.
M667 S3 selects CoreYZ mode. Forward movement of the Y motor moves the head in the +Y and +Z directions. Forward movement of the Z motor moves the head in the -Y and +Z directions.
M700: Level plate
bq ??? ??? ??? ??? No No ??? ???
1 only in bq-Marlin Firmware
Example: M700
M701: Load filament
Example: M701
M702: Unload filament
Example: M702
M906: Set motor currents
No Yes ??? ??? ??? No M907? ??? ???
Example: M906 X300 Y500 Z200 E350
The dc42 fork of RepRapFirmware supports an additional I parameter. This is the percentage of normal that the motor currents should be reduced to when the printer becomes idle but the motors have not been switched off.
Yes ??? ??? ??? ??? No ??? ??? ???
Set digital trimpot motor current using axis codes (X, Y, Z, E, B, S).
Yes ??? ??? ??? ??? Yes: 0.92 No ??? ???
M908 P<pin> S<current>
M909: Set microstepping
Example: M909 X3 Y5 Z2 E3
Set the microstepping value for each of the steppers. In Redeem this is implemented as 2^value, so
M909 X2 sets microstepping on X-axis to 2^2 = 4,
M909 Y3 sets microstepping on Y-axis to 2^3 = 8 etc.
M928: Start SD logging
Yes ??? ??? ??? ??? No No ??? ???
Example: M928 filename.g
Ended by M29.
M998: Request resend of line
Example: M998 P34
Request a resend of line 34. In some implementations the input-handling code overwrites the incoming G Code with this when it detects, for example, a checksum error. Then it leaves it up to the GCode interpreter actually to request the resend.
Example: M999
Other commands
G: List all G-codes
Example: G
This lists all implemeted G-codes in the firmware with description and sends it back to the host.
M: List all M-codes
Example: M
This lists all implemeted M-codes in the firmware with description and sends it back to the host.
T: Select Tool
Yes Yes ??? ??? ??? Yes ??? ??? ???
??? No ??? Yes ??? ??? Yes ??? ???
Example: T1
The sequence followed is:
  4. Use the new tool.
Selecting a non-existent tool (100, say) just does Step 1. above. That is to say it leaves all tools in their standby state. You can, of course, use the G10 command beforehand to set that standby temperature to anything you like.
Some implementations (e.g. RepRapFirmware) allow you to specify tool-change G Code macros. There are normally three specified (any of which can contain no commands if desired) that execute in this order:
  2. (Old tool is released);
With such implementations there is no wait for temperature stabilisation. That can be achieved by an M116 in any of the macros, of course.
After a reset tools will not start heating until they are selected. You can either put them all at their standby temperature by selecting them in turn, or leave them off so they only come on if/when you first use them. The M0, M1 and M112 commands turn them all off. You can, of course, turn them all off with the M1 command, then turn some back on again. Don't forget also to turn on the heated bed (if any) if you use that trick.
Marlin uses codes M500-M503 to manipulate EEPROM values.
xx can be one of:
ok
rs
On the latest version of Pronterface and soon Octoprint a special comment of the form:
// action:command
is allowed to be sent from the firmware, the command can currently be pause, resume or disconnect which will execute those commands on the host. As this is also a comment other hosts will just ignore these commands.
ok
start
Exceptions:
1. Marlin 1.0.0 Gen6 Firmware does not follow the two character rule. 'rs' is actually 'Resend' and '!!' is 'Error'. Example Lines:
  • Error: Line Number is not current line + 1. Last Line: 7
  • Resend: 8
  • Writing to File: print.gco
  • Done saving file.
  • File selected
2. The dc42 fork of RepRapFirmware responds to some commands with a reply string in JSON format, terminated by a newline. This allows later firmware revisions to include additional information without confusing clients (e.g. PanelDue) that do not expect it, and to make responses self-describing so that the client will not be confused if responses are delayed or lost. The commands affected are:
  • M105 S2
  • M105 S3
  • M20 S2
  • M36
  • M408
Problem to solve
When using Marlin firmware or emulating Marlin, each line of G-code sent from the host to the controller is answered with an ok before the next line can be sent without locking communications up. This slows down communication and limits the number of commands that can be sent per second to the printer controller, as the USB stack on the host and the serial interface driver on the Arduino add their own latencies (up to 10 milliseconds). This is not a problem for other controller electronics using native USB such as the Duet, because the standard serial-over-USB drivers provide flow control, so the host software can be configured so as not to wait for the ok.
Alternatives to G-code
